| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| Hi. I am configuring 3 nema 23 vexta 2A motors driven by the chinese TB6560 3 axis driver board and a 27V 13A power supply and controlled with EMC2. Everything seems to work well, despite the motor noise which seems to be caused by the cheap driver. One of my motors, however, is a bit more problematic. Sometimes, when powered but not jogging, it is jumpy and more noisy than the others. It also gets extremely hot, too hot to hold, while the others seem to remain cool. Is the motor just bad? Last edited by _AR_; 09-06-2010 at 04:32 PM. Reason: blew chip (see later post) |
| Wow, can't believe I didn't think of trying that. haha thanks. I switched the problematic motor's connection with another one, and it still acts the same, so it must be the motor. Is there anything one can do about a bad motor short of completely recoiling the coils? The thing works and does what I tell it to do, it just gets way to hot and is quite noisy. I do have extra motors I can use, I just originally planned on using these 3 since they are the same and had nice lead wires on them and good documentation to make hooking them up easier. I guess I'll see if these other ones I have work. They are 8 wire though and only have a pin connector without wire leads... I guess I'll heat up the soldering iron. |
I certainly don't, but I'd be curious about the winding resistance measurements (is the DC resistance of one of the windings - or half windings - very different from the others?)... |
| Hi AR, First check all connections, DB25 cable and your cnc software setup, if problem still exist then change connection of your problematic motor in electronic driver card with one of other good axis, if problem shift to good axis, driver card is partly damage and if not your problem is motor damage or mechanical problems of axis, replace motor with a good proper one, if problem still exist, you must check load momentum, lubricating, coupling alignment, deformation and other important mechanical parameters in your bad axis. Stepper motors are very sensitive to bearing ware, air gap clearance between rotor and stator, absorbing small iron particles to permanent magnet rotor and hard to repair. Best Regards, Gamron Last edited by gamron; 09-10-2010 at 03:04 AM. |
#10
#11
| Hi, I think nothing is wrong in your stepper motor and problem is simply current setting (with potentiometer or DIP switch) on your driver card for this lower impedance motor. You can clean and montage your motor and test with lower current setting on driver card. Regards, Gamron Last edited by gamron; 09-10-2010 at 03:40 AM. |
#12
| gamron, Are you referring to the first motor that didn't work, or the motor that blew the tb6560 chip? I will admit, I wanted to set the amperage to the lowest setting on the DIP switch before trying the motor that blew the chip, but forgot. I ordered 2 replacement chips, so maybe I'll try that one again... haha. The first motor I mentioned in the original post is a lost cause at this point, unless I can find a way to remagnetize it. Thanks again, AR |
| Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A | guy2b1 | DIY-CNC Router Table Machines | 16 | 03-08-2011 05:50 AM |
| Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board | wf1318 | Stepper Motors and Drives | 2 | 07-25-2010 02:19 AM |
| use satellite dish actuator motor as a stepper motor | ozni | Stepper Motors and Drives | 7 | 06-18-2010 07:55 PM |
| Integrated stepper motor? with built-in stepper motor driver | uirobot | Product Announcements & Manufacturer News | 0 | 06-07-2010 03:59 AM |
| Beltdrive-stepper motor-stepper motor driver | Georg | Stepper Motors and Drives | 0 | 10-16-2007 04:56 PM |
