Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 09-02-2010, 03:58 PM
AbuTarif is on a distinguished road
Cool My SLA7062M Driver Photos
I've finished building this stepper driver based on SLA7062 ,
The source was from PMinMO.com ,thanks to Phil ,
But actually it wont run my motor
Even when power it up the motor not clamp !!
Any body build this design before ??
http://www.pminmo.com/SLA7062/SLA7062.htm
ID:	113787   Click image for larger version
ID:	113788   Click image for larger version
Old 09-03-2010, 11:08 AM
Alex2005 is on a distinguished road
I have built this circuit, actually the older one since it was about 3-4 years ago now and it works ok. I do get this hissing noise from the motors when they are holding still, but it works. Have you got the motors wired to your DC power supply and the circuit itself?
Old 09-03-2010, 02:02 PM
Thanks Alex205 , yes I wired the motor common to the + of the power supply and the circuit itself , but still no hiss or vibration or any thing ,just the LED is ON .??
Actually I've build all of the known steppers circuit like LMD18245 ,AL3977 ,L297, .....
all work well except this !!!
Old 09-03-2010, 02:26 PM
Would you like if I take images of the circuit bottom and top and post here?
It does work well, I run at 40V I think, ages ago, just getting back into it. I can use at 3000rpm (little torque, slow acceleration, no stall. But 1500rpm nicely) on mach3.
Infact I have a 2x15V toroidal transformer wired series through bridge rectifier and 22,000uF cap so theorectically 42.3V.
I actually used package type sense resistors, very little inductance, and a quality bourns 10K POT set to 0.6 volts I think around 2.5-2.7 amps on a 3 amp motor winding.
Resistors were these model http://www.rapidonline.com/Electroni...s-TO-126/77297, but my supplier doesn't sell the 0.5 ohm anymore it seems.
let me know.
Old 09-03-2010, 02:54 PM
This is my circuit top and bottom ,,,
ID:	113864   Click image for larger version
ID:	113865   Click image for larger version
ID:	113866   Click image for larger version
Old 09-03-2010, 06:41 PM
Thanks to Phil who help me to figure out the problem ,which was only a loose connection between the positive and Pin16 of SLA7062M ,
Now it works ,
Old 09-04-2010, 09:12 AM
Thats good.
Can you tell me, do you get a hissing noise from your motor when idle?
Old 09-05-2010, 10:55 AM
Gold Member
RomanLini is on a distinguished road
The hissing noise is caused by ultrasonics from the current chopping of the driver causing the motor windings to ring. It's quite normal. If you set the SLA chip to synchronous mode when idle the noise is less, the chip has a control pin for this purpose.
The noise is also fairly dependant on PSU voltage, it is very different with different PSU voltages.
Old 09-05-2010, 07:32 PM
Drools's Avatar
Drools is on a distinguished road
Are there eagle sch and brd files available for this board?
Old 09-08-2010, 08:34 AM
quadtech is on a distinguished road
Eagle sch and brd are available here, albeit for a different board -
New SLA7062M 3 amp driver from Linistepper designer
Old 09-08-2010, 02:33 PM
Gold Member
Why not buy 3 SLAmStepper kits from James? The SLAm design solves many of the problems with other SLA chip designs including being much smaller and faster to build, designed for max reliability and it has excellent designed PCB with good attention to all the current paths etc designed by a SMPS designer (me!).
I've got 3 SLAms on my CNC machine with a 33v PSU and they give a very pro level of performance.
  #12   Ban this user!
Old 09-08-2010, 02:43 PM
Drools's Avatar
I have been looking at this driver, I have some unknown bipolar steppers STP-57D301that I'm thinking about using on a new 12x12 router. The unipolar steppers I have are not suited to the Linstepper so either I look for another unipolar driver or a bipolar driver. My unipolar steppers are 6 wire type and they might run in bipolar mode. I can do my own PCBs without a problem. Thanks for the help Roman!
[IMG] code is Off
New SLA7062M 3 amp driver from Linistepper designer James Newton Open Source Controller Boards 50 04-23-2010 10:39 AM
Sla7062m shahidmk Open Source Controller Boards 7 08-02-2009 06:18 AM
Need Help!- SLA7062M as PWM amplifiers? enok1969 General Electronics Discussion 1 06-22-2009 09:26 PM
A circuit board for the SLA7062M microstepping driver Edison4 Product Announcements & Manufacturer News 5 05-04-2008 03:59 PM
Where can I find some SLA7062M driver chips? radicooldude General Electronics Discussion 7 07-31-2006 08:15 PM
