Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 08-19-2010, 02:07 PM
TOM 1952 is on a distinguished road
Smile WHAT MOTOR ARE YOU USING
What KIND OF MOTOR ARE YOU GUYS RUNNIG TO GET ALL THESE 300 AND 400 IPM ON YOUR CNC ROUTERS?
I need a little help with this I have some nema 34 motor 640 oz they are 6 volt 2 amp induction of 12
I am using a g-540 drive which is better than the old one. 48 volt power supply . the problem is I can get the speed up to 280 ipm and after a little while running it starts to stall and I have to reduce it to 100in.
So what kind of motors do you guys have ? are they high $ ones like alpha ?
I looked at some with low induction and would match the 48 volt better would this help?
I am using mach 3 the gantry is about 80lb using 1.0 .250 ball screw direct drive.
Does anyone have some good advice
thanks
Old 08-24-2010, 01:06 PM
MrWild is on a distinguished road
more info needed. What are your lead screws? If 1/2-10 single start, you're doing good with the speeds you have. NEMA 34 motors have a slower top speed than NEMA 27
[IMG] code is Off
Need Help!- Changing Fanuc AC servo driver and motor for a regular VFD and async motor Bordaco Servo Motors and Drives 4 09-08-2011 05:41 PM
Replacement Motor Brushes For Sherline Mill AC Motor Lessons Benchtop Machines 0 07-16-2010 08:34 PM
Problems with motor stalling due to motor/lead screw alignment Bimmerkc1 DIY-CNC Router Table Machines 3 01-24-2010 06:12 PM
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
replacement motor for PML&Kollmorgen DC Brush Servo Motor fymroger Product Announcements & Manufacturer News 2 10-24-2008 03:36 AM
