| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| pls I am looking for a stepper motor type to drive a gear train which in turn drives a rack that drives a bolt to lock or unlock a door.I do not know how to go about the calculations on torque,speed , step angle,back emf, infact everything. I need help. its about my project:SMS controlled electronic door lock. pls everyone.say something.anything useful.Thanks. you can check my intended design. |
| Look at these; http://www.anaheimautomation.com/pro...ist.php?cID=52 Do a google for linear stepper motor . They are on ebay and some of the electronic surplus stores have them too. On this type of motor the shaft is threaded and the inside of the motor is a nut. The shaft moves in and out instead of turning. |
| I would agree with Geoff, do you really need a stepper motor when a simpler mechanism would do it. The start and end position appear to be defined and fixed, so why a stepper? A bit higher cost than a simple spring loaded solenoid is a Shot Bolt, if it is security you need. Al.
| A solenoid is usually limited in the amount of movement it can make. Plus a solenoid would have to be triggered both to open the door and close the door. most solenoids are spring loaded so it returns to the extended position when the power is released. |
| Need Help!- Mazatrol Dual Turn Fusion 640T (Door lock question) | Sammeh | Mazak, Mitsubishi, Mazatrol | 3 | 12-22-2010 09:06 AM |
| Need Help!- type stepper motor 42BYGH06004-12 | T-cue | Stepper Motors and Drives | 0 | 09-03-2008 03:44 PM |
| stepper lock new build | dgalaxy | General Electronics Discussion | 5 | 04-02-2006 03:04 PM |
| Preferred Stepper Driver Electrical Interface | JeremyLee | Polls | 4 | 02-26-2006 03:08 PM |
| what type of stepper motor to use | landart | DIY-CNC Router Table Machines | 0 | 08-26-2003 10:48 PM |
