| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hi there, I am planning on building a 3 axis CNC controlled milling machine / plasma cutter (as an XY Router), and today i might have found some nice stepper or servo motors. But, i can't find any detailed specs, so i would like to ask, who can tell me if these motors are servo's or stepper motors, what Nm, Voltage and Amps they work on...? This is the info on the label: MAE SPA OFFANENGO (CR) HY200 3437 0660 AK04 P/N F .U166 A3879I There are 4 wires going in, red, orange, black and yellow. Any info is appreciated, thanx many times! Mike, from the Netherlands |
Just use your multimeter to measure the resistance to cal. Rated Voltage = Rated Current x Resistance http://www.kelinginc.net/NEMA23Motor.html |
| Hey, I did a check this morning, red and yellow, and orange and black make 2 pairs/coils. Resistance turned out to be quite low, i think, on all 4 motors resistance was 0,5ohm on each coil. So, 6,6A x 0,5Ohm = 3,3V...? This can't be right, what am i missing here? |
| Hmmm, 6,6amps with only 3,3volts...? I can't even find a driver that can handle this, for this number of amps they usually start around 30 volts. If there's anybody out there who can find the original specs on this motor...? I've been looking "everywhere", but i'm a noob so i guess some of you know better where to look. |
| Maximum voltage for the motor is calculated by: V = 32*√inductance Typically the voltage applied to the motor will be 15 to 20 times its rated voltage.
__________________ Regards Geoff |
| Vexta Stepper Motor Specs | met4life | Stepper Motors and Drives | 9 | 03-05-2011 01:19 AM |
| Need Help!- Pittman Stepper Motor Specs | rjhinton | Stepper Motors and Drives | 0 | 06-11-2010 10:33 AM |
| Newbie- Stepper motor specs | Joshua | General Electronics Discussion | 1 | 03-10-2009 07:53 AM |
| Nema 34 stepper motor specs? | cncmad | Stepper Motors and Drives | 2 | 07-22-2008 11:57 PM |
