Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-29-2010, 01:16 AM
AvioP is on a distinguished road
tb6560 help me!!!!!!!!
Hello, I bought a tb6560 5 axis driver board. I use mach 3 sw for driving the step motors, but I have a problem : when I start mach 3 the holding torque about step motors go down and the step motors don't run, infact the 5 led about the axis segnals aren't bright. I set the pins following the driver boards instruction. When I go to see the active pins on mach 3 there are no output pin switch on. I think that the setting pins write in the instruction aren't ok. what do you know?
The pins are:
X ENALBED14 STEP 16 DIR4
Y ENABLED14 STEP 1 DIR17
Z ENBALED14 STEP 7 DIR3
THANKS VERY MUCH
SORRY IF MY ENGLISH IS POOR
Old 08-02-2010, 03:06 PM
Telly is on a distinguished road
When i start up Mach 3 the light go dim too. The reason my motors wouldn't run was because each axis needs to be enabled.
Go to "Config"
"Pots and Pins"
"Output Signals" Tab
And tick Enable 1-5.
I just left the numbers default. They don't tie up with the motor pins at all.
[IMG] code is Off
TB6560 timings EMC2 y2kiah Stepper Motors and Drives 20 04-28-2012 05:26 PM
need help with tb6560 board terryt General Electronics Discussion 94 03-14-2012 12:08 AM
TB6560 Board. Telly Stepper Motors and Drives 0 07-26-2010 12:32 PM
TB6560 woes draktheas Stepper Motors and Drives 0 03-28-2010 10:08 AM
4 Axis TB6560 (compatable) Zygoat Stepper Motors and Drives 3 03-01-2010 02:51 AM
