Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-25-2010, 02:38 PM
kreutz is on a distinguished road
K-4 PC Interface Schematics for Mardus-Kreutz Drives
Some time ago I designed the K-4 PC Interface boards for Bipolar micro-steppers to be compatible with the Mardus-Kreutz open source unipolar micro-stepper drive boards. Actually each K-4 board drives four M-K boards (4 axes) and include Lpt cable connector, charge pump, E-stop, etc. K-4 Board specs could be found on several threads and a couple of blogs.
Soon I will post all the design schematics and PCB, as well as the latest hex files for programming the on-board translators. Please, be patient, it will take a couple of days...
Best regards,
Kreutz.
Old 07-25-2010, 03:32 PM
Schematics Rev3.03SMD (latest revision)
Here are the schematics and PCB drawings
File Type: zip Kreutz-4-Rev3.03SMD_Interface board.zip‎ (1,011.1 KB, 315 views)
Old 07-28-2010, 02:27 PM
K-4 PC interface microcontroller's firmware
NOTE: This K-4 Firmware IS NOT compatible with individual tranlator boards for the Mardus-Kreutz drives!!
Enjoy!!
Kreutz.
Old 07-28-2010, 06:26 PM
K-4 PC Interface board's Specs
The PC interface board, also called the K-4 Interface, has B.O.B. (Break Out Box) functionality and interfaces four independent Mardus-Kreutz power stages. The design includes an expansion port (20 pin IDC connector) on the interface board, in order to provide access to the non used LPT port pins for functions like: axis limit switches, home switches, scanning probes, spindle speed control, spindle power control, vacuum or cooling pumps, etc.
General Characteristics:
Kreutz-4 Rev3.02SMD and up (K-4) is intended for low cost CNC or robotic applications. The main advantages of the K-4 hardware configuration are:
-Low Cost.
-No need to buy extra boards for basic CNC or robotic applications.
-Individual Power boards are easily and economically replaceable.
-Sophisticated features include: Individually selectable micro-step modes, reference current "morphing" versus rotational speed, automatic torque compensation, automatic stand-by current reduction, individual motor voltage and current adjustment for each axis.
-Basic protection/safety includes: 2500 V Opto-isolation & RF signal isolation, Reverse voltage protection on the 12Vdc input. Charge Pump feature (watch-dog).
-There is no need to open the PC or get another external power supply in order to provide the required non-isolated +5 Volts (supplied by using a standard USB cable between the PC and the PC-interface board).
-Customizable platform for O.E.M. or Value Added resellers.
-Easy and economical upgrade path to higher output bipolar or unipolar power boards.
-Optional External Interface board could be added later for additional control, power and safety features.
Old 07-30-2010, 07:22 PM
Finished K-4 PC Interface board
Here it is:
Old 09-01-2011, 05:47 PM
Julios is on a distinguished road
Hi Kreutz, congratulations on this incredible project ... Excuse my ignorance, but I need to mount the 2313 with the firmware recorded ?
Old 12-30-2011, 01:13 AM
No, there is an adapter I designed for programming the micro-contoller chips after assembling and reflowing the pcb (there is also a fixture to test each channel with a 2 channel oscilloscope and Mach3), please, send me a PM with your e-mail address in order to send you the schematics and usage instructions. It will require the STK-500 programmer or equivalent.
Best regards and Happy New Year!!
Kreutz
[IMG] code is Off
Diseno de la Tarjeta Controladora Micro-Step Unipolar "Mardus-Kreutz" kreutz Spanish CNCzone 266 05-30-2012 04:45 PM
Mardus-Kreutz Unipolar Microstepper, a simpler alternative. kreutz Stepper Motors and Drives 59 03-15-2012 10:45 PM
Need Help!- Will MACH3 interface to Heindenhain drives jbcj Mach Software (ArtSoft software) 4 06-06-2009 09:04 AM
Mardus-Kreutz Unipolar Micro-stepper Blog kreutz Stepper Motors and Drives 7 11-24-2008 07:12 PM
Mardus-Kreutz unipolar microstepper PCB, 80V -8 Amps kreutz Stepper Motors and Drives 4 10-31-2007 04:37 PM
