Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-24-2010, 12:50 PM
wf1318 is on a distinguished road
6 leads stepper motor connect to TB6560AHQ stepper driver board
Hello!
I have a 6 leads stepper motor (3.1V, 2.5A), and a TB6560AHQ stepper driver board.
However, this driver board only have A+, A-, B+ & B- connector, and no connector for the 2 common wire for the stepper motor......
OK, here are my questions:
1. I connect the A+, A-, B+ & B- wire of the stepper motor to the driver board, and the driver board can drive the stepper motor turning without the 2 common wire......
So, can I only connect the A+, A-, B+ & B- wire to the driver board without the 2 common wire of a 6 leads stepper motor???
2. With the above setup, I want to connect the 2 common wire to the main power of the driver board, just want to see the different result between 4 leads connection and 6 leads connection of the stepper motor. However, the voltage of the main power is around 20V, and my stepper motor only need 3.1V.......So, can I connect the stepper motor directly to the 20V main power???
Thanks.
Old 07-24-2010, 05:09 PM
johnd is on a distinguished road
6 wire hookup diagram
Go to gecko web site. They have a section in the "step motor basics Guide" on how to wire stepper motors. You have to determine half winding or full winding connection. The information is located in the "geckodrive technical support Library"
JohnD.
Old 07-25-2010, 02:19 AM
JohnD.
Thank you very much, johnd!!!
This is very useful
[IMG] code is Off
Need Help!- Stepper motor for 5 Axis TA8435H Driver Board alese Stepper Motors and Drives 1 10-14-2009 11:14 PM
Newbie- Stepper motor A vs driver board A tsknutsen Stepper Motors and Drives 2 03-13-2009 08:41 PM
Need help to locate stepper motor control board plus driver Techbuilder Stepper Motors and Drives 1 10-16-2008 08:53 PM
Need help to locate stepper motor control board plus driver Techbuilder DeskCNC Controller Board 9 10-14-2008 07:11 AM
Need Help!- How to connect 3A Bi-Polar Stepper Motor Driver from arceurotrade cor Stepper Motors and Drives 2 03-29-2008 09:43 AM
