Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-22-2010, 07:18 AM
guerd87's Avatar
guerd87 is on a distinguished road
Nema 23 Strength - N.cm Min in Oz? Not familiar
Hi everyone,
Im looking to order some motors and drivers through a company I found via the Mechmate website. The company is called Deitech - Driver Motor
They have a large range of motors available but Im not quite sure on the way they are rated. Im looking for a JGRO setup, around 300oz motors (equivalent to the the HobbyCNC ones)
http://www.driver-motor.com/ProductContent.aspx?ID=46
Are any of the motors here around that strength? How do I work it out?
The Driver I am looking at handles 50v, so I would like to get a motor to suit about a 48VDC power supply.
Im also looking at their drivers:
http://www.driver-motor.com/ProductContent.aspx?ID=50
4.2A Max 50VDC - Is this the right driver or should I be looking at another one of their models? They are based off the Leadshine models.
Thanks for all your help,
John
Old 07-22-2010, 12:30 PM
jschmitt is on a distinguished road
http://www.smallparts.com.au/technical/convert/ is where I found this
about 1 N/cm = 1.416 in/oz
Old 07-22-2010, 01:48 PM
pupfield is on a distinguished road
http://www.unitconversion.org/index.html
http://www.engineersedge.com/
Both have many unit to unit converters.
http://www.kelinginc.net/index.html
I found to be a good source for servos, power supplies, controllers, etc. I'm sure there are many others.
I had been playing with steppers for a while before using servos to build our machine. The servos have been very good compared to steppers. A bit more $$ but worth it.
[IMG] code is Off
Need NEMA 34 to NEMA 23 Adapter jjackson DIY-CNC Router Table Machines 11 06-30-2010 08:48 PM
nema 23 vs nema 34. how much power do I need? will gilmore Vertical Mill, Lathe Project Log 4 08-20-2009 09:13 PM
nema 34 1600 oz or nema 42 3200 oz? 15mgtar Stepper Motors and Drives 3 07-27-2009 05:53 PM
Strength? pp-TG Mechanical Calculations/Engineering Design 2 10-09-2008 11:53 AM
Standard Nema 34's vs Nema 34's with encoder/controller. SCCoupe DIY-CNC Router Table Machines 2 03-16-2006 10:03 AM
