Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-20-2010, 12:49 PM
BTD BTD is offline
BTD is on a distinguished road
Dragon Driver ramp capacitor
I'm using a Dragon Driver w/ a Keling 282 oz in stepper motor to power a plasma torch track burner.
This is a self-contained driver with on-board speed adjust, CW/CCW select, and on-off control via several low voltage contacts/pins. The only electrical components you need is the Dragon driver, a power supply, and the stepper motor.
To start and stop the motor, you ground (or unground) the "enable" pin on the driver board.
I need the ability to ramp up the motor speed from 0 to whatever speed I've pre-set so the motor doesn't lock up. Without the ramp feature, if the speed setting is too high, the motor locks up when you ground the pin. A low setting is fine but I really need the ability to run fast sometimes.
I can start out at a low speed and slowly increase the speed but that's not the ideal situation.
The Dragon driver manual says that the device has a provision for adding an extra capacitor to allow the speed to ramp up BUT there's a catch. It only works when you first apply AC to the board. That's no good. Under normal operation, AC is on all the time. The only time the motor spins is when you ground the enable pin and that's when I need the ramp function.
Does anyone here have experience with this Dragon driver and the ramp capacitor feature?
BTW...the capacitor I'm using is an electrolytic, 25 vdc, 220 uF and I do know that these are polarized.
Old 07-26-2010, 06:09 PM
johnmac's Avatar
johnmac is on a distinguished road
I have 3 of those drivers. I decided to go with Geckos, so I never really used them. I never bothered to figure out the ramping, as the ramping can be set in Mach.
John
[IMG] code is Off
Build Thread- Picstep DRAGON custom w/PMinMO BOB JohnnyVegas PicStep Controllers 42 10-19-2011 07:21 AM
Need Help!- Dragon Driver Model:29A55-A WeCheat Stepper Motors and Drives 13 08-15-2011 12:38 PM
{digitalPimple} Build - 'Dragon' CNC - Experimental JohnnyVegas CNC Wood Router Project Log 78 02-02-2010 01:11 AM
To Ramp or to Plunge? bborb General Metalwork Discussion 13 01-22-2009 08:50 AM
Problem- ramp milling almachinist Fanuc 3 01-20-2009 09:36 AM
