Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-05-2010, 03:16 PM
Andreas1 is on a distinguished road
Unhappy Stepper motor help!
How do the stepper motors work on a diy cnc machine , im thinking of building my own cnc router and want to know how it makes the z y x axis move and how to install.
anyone think they can help me?
Old 07-08-2010, 07:33 AM
vger's Avatar
vger is on a distinguished road
Thats a lot to cover....
Here is a link to a PDF about steppers...
http://www.solarbotics.net/library/p...f/motorbas.pdf
A stepper is driven with a "Stepper motor driver" most of which have inputs for "Step" and "Direction". The most common stepper motors will have 200 steps per revolution in full step mode. With the motor shaft connected to a long screw (M14 threaded rod with a 2mm pitch) then for every 100 steps of the motor you get 1mm of linear motion of a nut on the screw. The nut would normaly be affixed to the moving part of the axis. In some, the Z axis has the motor and screw assembly moving and the nut stationary.
Take a look at this page for some basic infromation..
http://buildyourcnc.com/default.aspx
Steve
[IMG] code is Off
Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A guy2b1 DIY-CNC Router Table Machines 16 03-08-2011 05:50 AM
use satellite dish actuator motor as a stepper motor ozni Stepper Motors and Drives 7 06-18-2010 07:55 PM
Integrated stepper motor? with built-in stepper motor driver uirobot Product Announcements & Manufacturer News 0 06-07-2010 03:59 AM
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 04:56 PM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
