Results 1 to 6 of 6
Thread: Stepper Motors and Voltage
    May 2005
    australia
    Cool Stepper Motors and Voltage
    The more I read, the more confused I get! Is it ok to run 24v into a 1.8volt motor? Is there a % of maximum volts you can run into a motor for its volt rating. I have 4x (1.8v 3a) and 4x (24v 4.4a) stepper motors. Both lots 6 wire. How many volts should I put into the motors to run a small hobby mill. Im running a "4xcnc10b" driver which handles 10 amps per phase per motor. (dtllc.com). Also, is it a general assertion that the amp rating on a motor is per phase? Any help would be much apreciated!
    Jan 2005
    Missouri
    Yes, the amp rating is per phase. I wouldn't go much beyond 15x the motors nameplate voltage rating.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Mar 2003
    Shelby Twp, MI....USA
    When you use higher voltages with that driver board, you'll have to use resistors to limit the current to the motors.
    Mar 2005
    when a higher rated voltage is applied to a motor and the rated motors current met, at this time the voltage applied should be backed off to its opperational rateing or untill its maximum current is met, otherwise the windings will get to hot and start to melt of arc.
    a higher voltage makes the motor go faster. you don't get much more torque as usually the saturation point is maxed out at the rating on the motors lable anyways.
    Mar 2003
    The higher voltage provides more torque at higher speeds.
    Mar 2006
    I offer free tech help on my products if you need help e-mail or call me:
    David Delagrange, Owner
    Delagrange Technology LLC
    4024 Fairfield Avenue
    Fort Wayne, IN 46807
    Phone: (260) 557-9280
    Hours: Monday-Friday, 5:00 p.m.- 9:00 p.m.
    E-mail: admin@dtllc.com
    http://www.dtllc.com
    1. Stepper motor: voltage vs. current ratings
      By cnczane in forum DIY CNC Router Table Machines
      Last Post: 09-08-2008, 01:14 PM
    2. Does anyone know of a controller board for synchronized stepper motors
      By Yellowbeard in forum Stepper Motors and Drives
      Last Post: 04-04-2005, 12:06 AM
    3. Looking for controller board for synchronized stepper motors
      By Yellowbeard in forum General Electronics Discussion
      Last Post: 04-02-2005, 09:50 AM
    4. Replies: 8
      Last Post: 01-26-2005, 08:10 AM
