Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-18-2010, 04:15 AM
norm535 is on a distinguished road
stepper question
on a long x axis with twin rack and pinion gears using two steppers, do you require two driver boards or can two motors be used in one driver board.
Thanks from Norm
Old 06-20-2010, 12:23 PM
jschmitt is on a distinguished road
I would use 2 drives because I don't think you can control current to the motors decently with one drive. Depending on size of motors, and if the motors were wired in parallel, or in series to each other, you would need either a high current driver, or very high voltage driver, or both, to make the thing run decent.
Here is a post the subject about a guy who tried it with sucess:
http://www.cnczone.com/forums/showthread.php?t=87407
Old 06-20-2010, 03:44 PM
RGeo is on a distinguished road
If it is at all possible to run one shaft to both pinions and use one motor. Perhaps it is physically impossible to do this, if that’s the case then excuse my post. If not, read on: A stepper, being open loop can easily get out of step with the other motor. This is still possible; although, less likely if you are running at low speeds with little or no load, as in a printer or a flame cutter, i.e. not tool load. However, if you are operating a router, lathe, mill, i.e. something with tool load, I think you’re asking for trouble when blind syncing steppers. This would give a whole new meaning to the word “rack”, as in all racked up. Opt for one motor and a common shaft, if at all possible.
Old 06-25-2010, 01:53 AM
thank you guys I was not sure if it was essential or a waste of money to use an extra driver board. better to be safe rather than sorry. so will go with 2 drivers now just need to decide which ones..... Huum let me think
Norm
[IMG] code is Off
Stepper on Z question SScnc Benchtop Machines 5 06-29-2008 09:55 PM
Stepper Question drafting101 Stepper Motors and Drives 6 05-31-2007 08:43 PM
Stepper Question ignatz Stepper Motors and Drives 5 04-23-2005 04:26 AM
Eek! Here is another Stepper/PS question CactusChip General Electronics Discussion 0 02-19-2004 09:35 PM
Stepper Question xairflyer DIY-CNC Router Table Machines 6 11-12-2003 06:30 PM
