Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 05-23-2005, 11:13 AM
roberto is on a distinguished road
Over Rating a Stepper, any consecuence?
I have been looking thru forums but no real answer found.
The situation its simple, I build a Home made board (thx to a friend David Setya Atmaja) to control 3 unipolar steppers (Vexta 5-Phase) rated at 12V 2.0 amp.
Recently i lost the 3 motors (some acid burn them out ) i was trying to find another 5-phase set of steppers but with no luck, so i decide to use a reprogrammed firmware to 2-phase steppers, but once again NO LUCK with the specs so right now i got:
12V 2Amp Controller Board
6V 0.7 Amp Vexta Steppers
The question is, will my motors die with that current?
It is 12V 2AMP too much for them?
I got in mind, 3 coils x 0.7amp = 2.1Amp (no problem right)
But what about that extra 6V? How that affect?
Thanks in advance,
Roberto R.
Old 05-24-2005, 05:00 AM
jerber's Avatar
Gold Member
jerber is on a distinguished road
If your board has some kind of chopper circuit, wich limits the current, it should be ok.
If it doesn't then you need voltage dropping resistors.
6V / 0.7A = 8,57 ohm ==> 10 ohm 5 watt resistor.
btw those 5-phase steppers are rare.
Old 05-24-2005, 08:18 AM
Well thx for the reply, this may sound a little dumb but....i dont know if there is a chopper circuit on that design the term is unknown to me
Yes, the 5-Phase steppers are very rare (even in my country :P here u can find almost anything rare) thats why i switch to 2-phase steppers, they were more accesible and easy to find.
There is the schematic on the attached files if anyone want to check it out and give some light.
Thx for the help
Old 05-24-2005, 01:25 PM
H500 is on a distinguished road
The circuit is not a chopper. You need to add power resistors to limit the current .7 amps per coil, or your motors will overheat.
Old 10-04-2007, 12:52 PM
hunter07 is on a distinguished road
and this circuit has not real 5 phase driving system
[IMGW]http://www.orientalmotor.com/MotionControl101/images/101/5-ph-fullstep.jpg[/IMGW]
Old 10-04-2007, 04:06 PM
[IMG] code is Off
Stepper Amperage Rating??? marshall1 Stepper Motors and Drives 1 03-20-2005 01:21 PM
Not good for a stepper motor? FLUTE HEAD Stepper Motors and Drives 4 12-01-2004 11:31 PM
Which stepper motor should I buy Graham S FAQ of CNC Machine building 0 08-27-2004 05:58 AM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 01:18 AM
disassembly of stepper motors dhprc2 General Electronics Discussion 8 06-25-2003 07:09 PM
