Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 05-22-2005, 06:03 PM
Cyclone's Avatar
*Registered User*
Cyclone is on a distinguished road
Control Box
Started to lay out my electronics....A good friend gave me a Nordson powder coating system control box....I stripped the old finish drilled all my holes for fans and such then we applied a new blue powder coat finish..... After a little modification to three cpu heatsink/fan coolers, I mounted the Geckos to the heatsink/fan coolers. These will draw fresh air into the enclosure and the fan from the PC power supply (for my 12v and 5v connections) will draw the hot air out...I also mounted the Bridge rectifier to a small cpu heatsink/fan. Heat...Bad, cool is good. If anyone is interested I will post how to modify the heatsinks to the Geckos.
ID:	7782   Click image for larger version
ID:	7783   Click image for larger version
Old 05-22-2005, 06:21 PM
motomitch1 is on a distinguished road
very nice job
Old 05-22-2005, 06:35 PM
OCNC is on a distinguished road
I'm interested!
Chris
Old 05-22-2005, 07:12 PM
Nono's Avatar
Nono is on a distinguished road
That is very cool...... Is that a board from a pc power supply in there? I am planning something a little more compact. But that is very cool. Did you use modified pIII heatsinks? After thinking about fresh air I was considering water cooling or peltier coolers to avoid any dust into the enclosure..
Post more pics if you get a chance..
Old 05-22-2005, 07:25 PM
Cyclone's Avatar
*Registered User*
Ok glad you asked...buy yourself three AMD heatsinks $10.00 each bought these from Tiger Direct CPU Cooler
Step 1 take off fan
Step 2 remove outer fins (I used a hobby bandsaw)
Step 3 modify retaining clip by making a "Z" bend to shorten the span until it fits Geckos tabs
Step 4 trial fit on Gecko Drive (the tabs on the drives where exact fit. I wonder if that was on purpose or pure luck?)
Step 5 re-assemble
Step 6 (optional) stare at them for a while or until wife starts to look at you funny!
PS. I used the fans as my mounting point on the case. Longer sheet metal screws did the job, they screw between the fins (no threads). Apply a dab of thermal paste to maximize heat transfer.
ID:	7785   Click image for larger version
ID:	7786   Click image for larger version
ID:	7787   Click image for larger version
Old 05-22-2005, 07:32 PM
2muchstuff is on a distinguished road
A heatsink and a fan for under $10, a little modification and it looks like something that wasn't rigged, very professional looking. I want some.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 05-22-2005, 07:37 PM
Cyclone's Avatar
*Registered User*
Yes "Nono" it is an old pc Power supply. The type before ATX came out. You will need to attach a 12v bulb (halogen) to any of the 12v outputs (yellow wires) to provide a load otherwise the voltage drops. You also get a 5v (Red wires) which will provide my 5vdc to my drives (I think).
(edited error on color of wires, thanks Al for catching it)
Old 05-22-2005, 07:43 PM
Nono's Avatar
I am not sure what the bulb does again? On Off light? Still very cool though.
Old 05-22-2005, 07:50 PM
Cyclone's Avatar
*Registered User*
When you first switch on a pc power supply it provides 12v output, fan runs at high speed, when it recognizes that there is no load it drops to 3v the fan then slows to a crawl (The power supply needs to have a load in order to provide the 12 volts otherwise the voltage drops) in a PC the motherboard and CPU is the load.
Old 05-23-2005, 07:18 AM
JavaDog's Avatar
JavaDog is on a distinguished road
Very nice box! I'm going to have to use your idea for the Geckos, brilliant!
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 05-23-2005, 07:56 AM
Al_The_Man's Avatar
You also get a 5v (yellow wires) which will provide my 5vdc to my drives (I think).
I believe yellow is 12v, Red is 5v on a PC supply?
  #12   Ban this user!
Old 05-23-2005, 08:06 AM
pen25 is on a distinguished road
and dont forget you need to equilize the air in and the air ouy of that box. the power supply fan wont exhast enough air. best way is pull air from low to high and across the components. i have seen a bunch of people do this incorectly and actually cause heating problems. IE trying to exhaust more air then the case can draw in or not being able to exhaust more then being sucked into the case. if you find pressure being built in the case best thing to do is add some holes for exhaust.
[IMG] code is Off
G-Code to DXF WayneHill OpenSource Software 200 04-22-2012 09:51 PM
Visual Basic Controller Project dwwright Visual Basic 29 02-14-2011 01:24 PM
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 03:08 PM
Rutex control box design trickey19 Servo Drives 7 04-25-2005 03:13 PM
Control Box Woodie1 DIY-CNC Router Table Machines 2 06-05-2004 07:44 AM
