Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-09-2010, 02:42 PM
CNCDevil is on a distinguished road
Driver and commons
Hi
I'm building a control box and have connected the common wire for the driver power supply, to the metal casing. Terminal 1 (common) of my drive (Centent CN0162) is in contact with the metal casing, through the baseplate of the drive. There is no measureable resistans between the casing and the terminal.
Is it necessary to draw a wire to the terminal, when it is already in contact with the casing?
Thanks,
Brian
Old 06-09-2010, 03:11 PM
Al_The_Man's Avatar
Not quite sure of what you have, but the general rule is even if the common is connected to Ground, ground should not be used as a conductor.
IOW, commons should always be run separate to ground, even though they may be at the same potential.
Old 06-09-2010, 04:01 PM
Thanks, I better follow the rules :-)
Some pictures of my project.
Best Regards,
Brian
ID:	108827   Click image for larger version
ID:	108828   Click image for larger version
Old 06-09-2010, 04:12 PM
Al_The_Man's Avatar
In your main enclosure it pays to set up a common ground plate where the service ground and all the bonding conductors to motor frames etc are connected, including cable shields.
Old 06-09-2010, 04:19 PM
In front of the terminals of the drives, I will mount a DIN rail all along the casing. The stepper cables shields will then be attached to this rail, along with all other shields and grounds. This should do the job.
Brian
[IMG] code is Off
Newbie- Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver? joprinz General Electronics Discussion 4 04-28-2011 03:57 AM
Need Help!- driver MR MOTION Controller & Computer Solutions 1 11-14-2009 10:45 PM
single axis driver and a b.o.b.,or multi-axis driver board .xXACEXx. Stepper Motors and Drives 3 07-02-2007 11:13 PM
STEPPER DRIVER FAQ {Stepper/driver amp per phase match. huios Stepper Motors and Drives 0 08-27-2006 08:43 AM
