Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 05-31-2010, 09:27 AM
Dirkos is on a distinguished road
Help! Y-axis is moving up
There is a strange problem with my machine.
The y-axis is moving after each direction change 0.1mm towards the machine.
There is no backlash, the machine uses "Rollvis".
This is my test code;
Y50F250
Y0F250
Y50F250
Y0
Etc.
When I repeated this like 17 times, and the last code was y0,
there is a zero point movement of 2.5mm towards the machine?
I dont have an explanaition for this, could anyone help me?
It seems like the y-axis does move 50mm in one way, but in the other way it moves about 49.9mm.
Old 05-31-2010, 09:44 AM
TarHeelTom is on a distinguished road
I'm certainly not the expert, but I'd try running the same code with the feed rate reduced to, say, 200.
Are your ways well lubricated?
Tom
Old 06-03-2010, 04:09 AM
Hello Tom,
Thanks for the reply, I expected much more support but there is only one reply.
This weekend I will try your remarks.
By the way I use a Deckel GNC-1, on this axis there is 7.5 Nm steppenmotor.
The spindel in the y-axis is of type "Rollvis", a special type.
I think greasing the axis will not settle the problem, there is to much power.
Thanks,
Dirkos
[IMG] code is Off
Newbie- Z-axis stopped moving while calibrating Charles2 Bridgeport and Hardinge Mills 5 11-27-2010 02:51 AM
(5 axis) Mach 3 not moving C B axis hamooteh Mach Software (ArtSoft software) 12 03-22-2010 12:49 AM
Is moving along Y unnecessary when using the 4th axis? Arquibaldo DIY-CNC Router Table Machines 8 07-18-2008 11:16 AM
Need Help!- Y axis moving without being programmed HMB-1 carbidecraters HURCO 1 06-22-2008 12:51 PM
Axis are not moving Reef Guy Mach Software (ArtSoft software) 4 09-13-2006 08:42 PM
