Page 1 of 5 1234 ... LastLast
Results 1 to 12 of 52
Thread: Electronic Utopia Bi-Polar Board (or other Bi-Polar boards)
    Apr 2005
    Does anyone have experience with them?
    I am still in the process of trying to decided on drives ...
    Atleast just some starter drives until I have the money to move up to Gecko's or ?
    Has anyone used the Parallel Port Interface Card from CNC4PC and the Electronic Utopia Bi Polar Card to control 3+ axis?
    Just looking for any input.
    I have been leaning towards ArcSin (www.buildyouridea.com) ...
    But want to consider all bi-polar options first.
    Thanks in advance
    Gold Member jerber's Avatar
    Nov 2004
    Netherlands
    I only have experience with PICStep,www.fromorbit.com/projects/picstep/. I've built one so far and it's working realy great.
    When I get all parts this or next week, I'll complete the remaining two.
    Building a PICStep is relatively easy and cheap but you have to make your own pcbs.
    And for a interface to your parallel port, I've put some optocouplers on a piece of prototype board. The PICStep has also microstepping so maybe you don't need to move up to a Gecko.
    Registered DieGuy's Avatar
    Apr 2005
    I have been using a Xylotex on my setup with great success using 270 oz-in automation direct steppers. My PSU is 28.7 vdc and the setup is adequate and a good value for the money.
    Apr 2005
    Thanks for the additional info guys! (Keep it coming)
    The 276 oz/in Automation Direct steppers are the ones I am planning on using ...
    After deciding those were the ones I would go with ...
    I found out Automation Direct is located about 2 miles from my house - lol
    I couldn't believe it ... which means I have to pay tax but no shipping.
    What matierial(s) are you working with?
    I am planning on plexi/plastic/delrin and aluminum.
    Also, are you running them at the full +/- 2.8 A/phase?
    Or at 2.5 A/phase?
    So ...
    The Xylotex may be an option with the motors I am planning on
    In regards to the PICStep ...
    While I am not 100% opposed to eching my own boards ...
    However, I would prefer to either buy a board already etched.
    I don't mind populating a board at all.
    So the PICStep is still a possibility if it saves money and/or offers something I need. (How much did it cost to build the one board?)
    One such board that I ran across was the EAS MicrostepPLD (or the Microstep)...
    http://www.embeddedtronics.com/microsteppld.html
    While I would have to build two boards in order to have three axis ...
    That would leave a fourth axis available for future use.
    I just need to figure out what it would cost parts wise to build one to see if they are worth considering too.
    Apr 2005
    I have a question regarding the Xylotex and the power supply.
    I already have a 24VDC power supply and it has a inline relay rated at 25A.
    Please forgive my ignant question ...
    I know the voltage rating is safe ...
    But ...
    Would this power source be safe to use since the relay is rated at 25A?
    Or would the higher amperage cause damage to the board?
    I guess the answer really helps me(and anyone else) with any of the boards but the Xylotex is the one that prompted checking the power supplies I have.
    Mar 2003
    Shelby Twp, MI....USA
    Do you mean fuse when you say relay? The Xylotex will only draw as much current as it needs. Having a higher current supply won't hurt anything.
    The nice thing about the embeddedtronics board, is you can run it at double the voltage of the Xylotex, which should double the top speed you'll be able to get.
    Apr 2005
    Quote Originally Posted by ranman
    Or at 2.5 A/phase?
    So ...
    Steel & aluminum on a Taig Milling machine
    I have mine backed off a bit from maximum. The Xylotex likes my 28.7 VDC (20VAC transformers) supply but if you set the board to the max Vref setting to get the current MAX then it tends to overheat. The MAX Vref that controls the current is 3.6 vdc but I have mine set to 3.45 vdc. If I had it to do over I would build the supply with a 24VAC transformer which would have made the peak volts around 31.5 - 32 VDC. The Xylotex will is rated @ 35VDC with BEMF (Motor generated voltages) Any more and you will let the magic blue smoke out of the parts.
    Apr 2005
    Quote Originally Posted by ger21
    Yeah I looked at them and they seem very nice, but I don't think my soldering skill would make it.
    Mar 2003
    Quote Originally Posted by DieGuy
    You really shouldn't run a Xylotex over 30V. 32V will probably let the smoke out as well. 35V is the absolute maximum, there is no extra room for error there.
    Apr 2005
    Thanks - That is what I thought .. but I also know what assuming things can do ... lol
    It's a relay and not a fuse ...
    OMRON G7L-2A-TUB-J-CB-DC24 (Or a close variant used in Danka Fax/Copiers)
    Actual number is G7L-2A-TUBJ ... rated at 24VDC
    So based off the info at ... http://oeiwcs.omron.com/webapp/comme...73&prmenbr=316
    It appears to be a 25A relay ...
    There is a switch hooked up to the relay to turn power on and off.
    I will just need to rig a button to cover/press the lever or maybe replace the existing switch with a toggle or rocker.
    For what its worth - the power supply was salvaged from a Danka/Xerox Fax Machine.
    Apr 2005
    Well ... I am now open to either the Xylotex or embeddedtronics boards too
    So I can decide if they are viable options or not, I need to figure out how much it would cost me to make the EAS boards.
    DieGuy - It's good to know that your doing Aluminum(and steel) with the Automation Direct 276 oz/in and Xylotex.
    Apr 2005
    For anyone following this ...
    The EAS boards are worth a look and may be what I go with (Depending on the budget when I click "buy")...
    They are right there with the Xylotex, and other options.
    Right now I have 4 possible boards/combos I may go with (in no order):
    1. Xylotex
    2. ArcSin
    3. EAS
    4. CNC4PC/Electronic Uptopia (Breakout/Bi-Polar Driver)
    Each one has it's advantages from being cheaper to offering better performance for not much more cost.
    Gecko's are a given choice .. but out of the price range I am currently looking at.
    I want to stay under $225 if possible ... and, if it's do-able, under $150 is even better.
    From digging a little deeper in this forum - Ok all the way through it
    It's looking like I will be going with Xylotex (atleast to begin with) and maybe add a EAS board later if I decide to add a 4th or 5th axis.
    But If I can find the extra $$, I may just go ahead with the EAS to begin with.
    I would still like to hear about any other options there may be ..
    The options are nice to know, whether it helps myself or someone else decide.
  • Page 1 of 5 1234 ... LastLast
    1. question about 2 X 2axis boards
      By Stevie in forum General Electronics Discussion
      Last Post: 03-14-2004, 07:39 PM
