Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 05-23-2010, 11:41 AM
BTD BTD is offline
BTD is on a distinguished road
Need simple non-cnc stepper motor driver
I need a simple (one-piece, self-contained?) power supply/motor controller for the stepper motor. 120 vac in....wiring to stepper motor out.
I want to use a NEMA 23 stepper motor for a plasma torch track driver.
There's no computer interface....all manual control.
I need adjustable speed, forward/reverse selection, and two discrete inputs for limit switchs. RPM or pulse frequency readout would be nice.
Please help!
Thanks guys...
Old 05-23-2010, 11:53 AM
serriadh is on a distinguished road
Sounds like you've just asked for all the major things a CNC driven axis needs, bar the facility to parse and run g-code ;-)
You may find that it is quite practical to use a standard DC motor to do the driving here, as you don't need precise positioning between limits. The controls will be much simpler and you're more likely to find an off-the-shelf speed control and reverse package. Me, I'd scour ebay for likely looking devices. You may have better things to do with your time, however.
Old 05-23-2010, 12:08 PM
RC-Archer is on a distinguished road
I think that I need the same thing but for testing and setting up stepper motor drives and lead screws.
Old 05-23-2010, 01:06 PM
amishx64's Avatar
amishx64 is on a distinguished road
Please help!
Thanks guys...
This sounds like a good little microcontroller project. Are you looking to do DIY?
Old 05-23-2010, 01:34 PM
Kipper's Avatar
Kipper is on a distinguished road
Sounds simple enough! Programmable Stepper Drivers
Keith
Old 05-23-2010, 07:41 PM
BTD BTD is offline
Thank you all....
Kipper, that link isn't working for me.
amishx64, I'm not very savvy re microcontrollers (pic?, basic stamp?). This will be DIY as far as the mechanism is concerned but I wanted to use off-the-shelf electronics.
serriadh, I looked at DC motors but am concerned that the speed won't be constant and I think I need pretty much constant speed for a plasma torch. I'm going to look again though. I'm thinking that a stepper will pretty much be a constant speed motor up to the rated braking torque.
I also looked at outright purchase of a OA torch track burner but they aren't cheap...several thousand dollars.
I've priced the stepper motor and power supply from Keling (approx $110 total) but the drivers I've seen seem to demand a computer interface.
Again, thanks all.
Old 05-23-2010, 08:02 PM
BTD BTD is offline
RC-Archer - just saw this. It's a little expensive for what I want but might be what you're looking for.
http://www.velmex.com/motor_control_vxm_j.html
Old 05-23-2010, 08:22 PM
BTD BTD is offline
Kipper....ok, the link works now.. http://www.electrozoneuk.com/
This is pretty much what I was looking for....just add power supply and stepper motor and off we go...you da man!
RC-Archer, you might consider this too. Seems to max out at 2 amps but will work for me.
Old 05-25-2010, 08:54 PM
Thanks for the info, BTD.
Old 05-26-2010, 02:04 PM
Kipper's Avatar
I reckon it can be interfaced to another driver ie the step/dir part to drive anything..... I built some miniature 4th axis units and a CCTV dome with those a few years back......The larger power version seems to have been in development forever so don't hold your breath waiting on it.
Keith
[IMG] code is Off
Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A guy2b1 DIY-CNC Router Table Machines 16 03-08-2011 05:50 AM
Need Help!- Stepper motor to simple power feed? machining fool Stepper Motors and Drives 2 04-12-2008 10:08 PM
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 04:56 PM
Looking for simple stepper driver help dubious Stepper Motors and Drives 3 03-14-2007 01:19 PM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
