| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
| Hello eveyone first I would like to thank you all for the help you are giving and the support now my problem is I have a broken copier machine so I thought to get the motors and drivers from it the driver board that used in the machine is using the A2918SW drive IC I want to know how can I take this a part and use it to control the stepper motor from the parallel port of my pc I am using mach3 for controlling as I know the 2-9 data can be used in the port but where it should go on the IC?? to what pins? what is the voltage to operate the IC and if there is a circuit diagram to the IC? not the internal diagram but the full opreating diagram. please help me on that. thank you all in advance |
| Hello dude. I just find in the same situation since last month i gott the same printer machine and the same board. Wait a week and i will try to figure it out. Should be not to dificult to use it. You are planing to use the motor wich came pluged to the board? I didnt like it too mach. May be i will look to set up for more powerfull motors. The schematic of a2918 suggest a peak current of 1.5 amps, and that should be enough for good torke results. Chears. See you next week. |
| Shunt circuit | fahque99 | General Electronics Discussion | 14 | 08-04-2009 11:54 PM |
| led in circuit | graphpix | General Electronics Discussion | 5 | 12-27-2007 01:25 PM |
| Dump circuit | Pbrew1 | Servo Motors and Drives | 1 | 07-24-2006 11:15 PM |
| Circuit Help | Shanghyd | General Electronics Discussion | 9 | 09-16-2005 08:02 AM |
| Circuit needed | jimini | DIY-CNC Router Table Machines | 5 | 09-04-2003 08:06 PM |
