Jack,
Here is the Vexta wiring and spec's, I am still looking for the Pac Sci data I have filed away somewhere.
Jeff...
I have some steppers that I can't find a wiring diagram or specs for
One is a Vexta PH268-21 6 wire
The other is a Pac Sci Sigma 802D2235-F037S 8 wire
Anyone know where I can find info on how to wire these?
Thanks,
Jack
Jack Mc Kie
[URL=http//www.freshwatermodels.com]Freshwater Models[/URL]
Jack,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Jack,
I am not sure if your Pac Sci motor has this wire color combination.
Jeff...
Jeff,
Thanks very much for the info on the Vexta!!!!!!!!!!!!
The pac sci has the following colors paired up
Black/white w-orange stripe
Red/white w yellow stripe
Orange/white w-black stripe
Yellow/white w-red stripe
I don't see any voltage for teh pac sci?
Jack
Jack Mc Kie
Jack,
The voltage is not that critical, the current on the other hand is.
What stepper driver do you plan on using?
Jeff...
Jeff,
The board is a Mechatronics. I had it on another machine but replaced it with a Gecko250. Either I want to use these steppers for now or I have to buy 3-4 steppers. If I buy them I want 270-300 inch ounce. I have a feeling that I will have to buy some steppers....
Jack
Jack
Jack Mc Kie
