| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Well ive spent the last two nights trying to figure out what i need for current limiting resistors for our router build and im throwing in the towl and asking for help We are building a jgro style router with a 97" long (in Y) table and using nema 34 framed motors spec sheet's here http://www.kelinginc.net/KL34H280-45-8A.pdf The powersupply we are going to go with is giving us 36v DC with more than enough avaiable amps (borrowed it from an old 3axis cnc with massive ac servo's and built a rectifier for it) Now from my math, i think i need 3.28ohm 330watt resistors or if split them up and run two resistors per motor (wired unipoler) i can go with 6.5ohm 165watt resistors Is this correct? or am i wrong? And either way, what do i need and where can i buy them? Digikey is showing $80 for resistors large enough by math, im hoping im wrong Thanks -Jacob |
| The motor is 4.5A and 0.71 Ohms unipolar. You have a 36VDC supply. 1) The motor "takes care" of 3.2V (4.5A times 0.71 Ohms) so that leaves 32.8V (36V - 3.2V) you have to drop. 2) 32.8V divided by 4.5A is 7.3 Ohms. You will need two of them. 3) 32.8V times 4.5A is 148 Watts. Two resistors are needed per motor so you will be dissipating nearly 300 Watts of heat per motor in these resistors. 4) Big resistors are expensive and $80 doesn't sound unreasonable for the size parts necessary to dissipate this much heat. For your trouble you'll get fairly poor performance (10:1 voltage overdrive ratio, full or half-step resolution, resonances, etc.). Mariss |
| Choppers VS Limiting Resistors | camcam | Open Source CNC Machine Designs | 2 | 04-20-2008 12:00 AM |
| Sensing Resistors vs Current limiting Resistors | whitney | Hobbycnc (Products) | 3 | 11-05-2006 11:29 PM |
| Calculating series load resistors | whateg01 | Stepper Motors and Drives | 49 | 12-03-2005 10:28 AM |
| Calculating current limiting resistors (I need serious help) | Konstantin | General Electronics Discussion | 13 | 07-25-2005 04:10 PM |
| Clarification needed on current limiting resistors | ccm | General Electronics Discussion | 1 | 01-11-2005 09:16 AM |
