Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-31-2010, 01:10 PM
15mgtar is on a distinguished road
is this normal?
my stepper run so hot after 2 hours that I can not touch it. Is this normal?
I don't have a thermometer to measure how hot it is but guessing it is under 100C and well above 70C
Old 03-31-2010, 04:37 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Steppers DO run hot. It could well be in tolerance but be too hot to touch. Touch it with a wet finger. If it sizzles, then it's definitely too hot.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
Old 03-31-2010, 06:01 PM
CalG is on a distinguished road
Fan cool it, It will run cooler. I was surprised to read some Compumotor literature where the motor current rating was noted "when attached to a 12" X 12" X 1" aluminum plate. Cool!
[IMG] code is Off
Normal Cut and Deep Cut waleed alhadidi Kellyware CAM 0 01-22-2010 05:49 PM
Need Help!- Gremlin or Normal? Mr.Chips Gecko Drives 9 01-19-2010 07:12 PM
Problem- This is NOT a normal noise Dancy Fanuc 11 05-24-2008 04:26 PM
Way stains Normal? Dan S Mini Lathe 1 09-27-2006 03:50 AM
How much vibration is normal? kombayotch Bridgeport and Hardinge Mills 1 02-17-2006 05:55 PM
