Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-28-2010, 10:08 AM
draktheas is on a distinguished road
TB6560 woes
I just bought this board: http://cgi.ebay.com/NEW-4-Axis-TB656...item2c53c80e16 and I can't get the steppers to move.
More info. I am using this power supply with voltage decreased to 28V: http://www.kelinginc.net/KL-350-36.pdf and these steppers: http://www.kelinginc.net/KL23H276-28-4B.pdf
By manipulating the dips, I have tried all current settings, decay settings and microstep settings. The motors do not ever lock when only power (no parallel port) is applied. However, the board does show solid on activity LEDs at boot up of the PC. When using Mach3 and running GCode, I see quickly blinking activity on all four activity LEDs and they correspond to the axis that is moving so it seems like at least the ports are configured correctly in Mach3. I have Mach3 configured as described in this manual: http://www.savebase.com/infobase/dow...xis_Driver.doc
Pictures of wiring attached. Did I get a bad board? Any help would be greatly appreciated.
EDIT: Never mind. Turns out the ground connector on the board had a crappy solder blob. I re-soldered it and everything started working.
Thanks,
Drak
ID:	103866   Click image for larger version
[IMG] code is Off
need help with tb6560 board terryt General Electronics Discussion 94 03-14-2012 12:08 AM
Mac 3 setup for TB6560 controller board davidarf General CNC (Mill and Lathe) Control Software (NC) 1 07-27-2011 02:31 AM
TB6560 3-axis driver from ebay kish89 Stepper Motors and Drives 10 06-30-2011 07:10 PM
need help with 3 AXIS (TB6560) CNC DRIVER BOARD Jason Miller General Electronics Discussion 34 01-06-2011 12:25 PM
4 Axis TB6560 (compatable) Zygoat Stepper Motors and Drives 3 03-01-2010 02:51 AM
