Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-19-2010, 12:56 PM
Deb.bosch is on a distinguished road
Gecko G540
Hello
My question is for all the Gecko users. I want to use the G540 stepper drive and the source of step and direction is a ControlLogix PLC.
1.Would a 48V, 10A power supply be good enough for the G540.
2.I am not using a Mach3, so can I can give the step and direction signals directly to the terminals 2 to 9 at the DB25 parallel port at G540.
3.What exactly is fault mode that is mentioned in the setup guide.
4.What are the maximum no. of connections that can be made at a particular terminal
Old 03-19-2010, 08:40 PM
debetto is on a distinguished road
Originally Posted by Deb.bosch View Post
Hello
I can answer the first question. Power supply for the G540 has to be between +18V and +50V DC and a current rating of 2/3 times total current rating of stepper motors with max of 3.5A per motor. Your power supply works and can handle four 3.5A motors. Pick motors with a winding inductance of 2.5 to 3.0 mH per phase for maximum speed.
[IMG] code is Off
Need Help!- gecko g540 on a lathe ??? Bennyboyz777 Mini Lathe 9 03-06-2010 05:37 AM
Newbie- ZAY7045 + Gecko G540? clocker Benchtop Machines 42 01-13-2010 08:48 PM
Need Help!- Gecko G540 Relay Help The CNC Man Stepper Motors and Drives 2 12-03-2009 04:11 PM
Need Help!- Gecko G540 rotger Servo Motors and Drives 0 06-02-2009 12:43 PM
gecko g540 Teyber12 Benchtop Machines 3 05-31-2009 02:23 PM
