Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-16-2010, 10:43 AM
Marty_Escarcega is on a distinguished road
Clausing Lathe Conversion, direct drive or reduced drive
I am planning on converting a Clausing 12"x24" lathe. 2hp spindle motor. My question is whether or not to use a large enough stepper to drive the lead and cross feed screws rather than reducing them with pulleys. I have a 78VDC unregulated power supply and plan to use Gecko stepper drives.
I'm in the research mode right now. I would rather match up everything for good reliable peformance. I went to Microkinetics website to get an idea what they use for their similar sized lathe.
Any advice and direction appreciated. I want to buy the steppers and drivers once and set up once. :-)
[IMG] code is Off
Need Help!- Direct Drive Plasma - Motor/drive/power supply? CPierce18 CNC Plasma and Waterjet Machines 1 02-05-2010 05:53 PM
Need Help!- Direct Drive Plasma - Motor/drive/power supply? CPierce18 Stepper Motors and Drives 0 01-29-2010 01:01 PM
Newbie- CNC Lathe - Servo direct drive or pulley drive? s76tools General Metal Working Machines 1 09-06-2009 11:17 AM
Direct drive vs. Belt Reduction - Mini Mill Conversion sanddrag Benchtop Machines 2 02-10-2006 10:00 AM
X3 conversion using big servos - direct or belt drive?? messar Benchtop Machines 13 01-27-2006 03:19 AM
