Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 04-21-2005, 11:47 AM
Cold Fusion is on a distinguished road
How much torque is needed?
I'm looking into buying a Bridgeport Series 2 nc mill and retrofitting it with a pc control. Since I'm comfortable with the gecko system, this is what I want to stay with. Now the question becomes stepper or servo, as well as how much torque. I'de like it to be a decently fast system, but rapids over 100ipm are not needed. I forsee a lot of aluminum being milled, and on rare occasions steel.
Proud owner of a Series II Bridgeport.
Old 04-21-2005, 01:04 PM
*Registered*
ESjaavik is on a distinguished road
Here is the "works for me" figures:
My mill is about the same size. I run 10Nm stepper on X, 6Nm on Y, and 12Nm on the knee. The last one is not strong enough, I can only run around 50mm feedrate in Z. X and Y will do F=600mm. This is with preloaded ballscrews 30mmx5mm on X, 23mmx5mm on Y and 32mmx10mm on Z. For Acme screws you need 2-3 times bigger motors.
The drives runs 12A/70V on X and Z, and 9A/70V on Y.
X runs directly on the ballscrew, Y over a belt, don't remember but it's close to 1:1.
Z is geared down quite a bit, I don't remember how much at the moment. Anyway it's my recommendation you try to move the quill for a much faster Z. I have just not found out how I can do that with enough accuracy on mine. On the BP there are several solutions.
I might add that on my machine Y moves the spindle and not the table, so it has a lower mass than X (the table).
I'm not satisfied with the speed, so will upgrade to servo. It is my prediction you will not be satisfied with 254mm/min after a short while.
Old 04-21-2005, 01:19 PM
I've been researching servos and it has me very confused. Do I want DC, AC, brushed, brushless? The stall/continuous ratings also has me a little confused.
[IMG] code is Off
How much torque is needed? CNCadmin General Metal Working Machines 0 03-22-2005 02:13 PM
Stepper Motor High Torque Low Amp Sanghera Stepper Motors and Drives 13 03-21-2005 06:16 PM
How much Torque is needed? Tjippy DIY-CNC Router Table Machines 5 12-02-2004 02:56 PM
Stepper question: torque re: current cnczane Stepper Motors and Drives 14 10-21-2004 08:30 PM
dc servo motor torque SJ781 Servo Motors and Drives 19 06-08-2004 03:38 AM
