hello
I read through this forum but to be honest my limited knowledge about the subject prevents me from understanding some of the terms listed and how to deal with them.
I built a 3m by 1.8m cnc machine and had it up and running until I decided to upgrade my 700W spindle motor to a 3.5kW one complete with a VFD.
The problem I'm facing is that my carriage now weighs about 14KG (about 31lbs) and my openbuilds NEMA23 motor cant lift the spindle anymore for Z-axis movement. X and Y axes still work fine, both are also using NEMA23s.
The Z axis holds the spindle motor and drops it fine but cannot lift it, i can lower the spindle motor and keep it still but cannot get upward movement, when I try it just tries to spin upwards but ends up slipping downwards.
What I want to know is if I upgrade to a NEMA34, will I be able to fix this? Do I need to upgrade my driver as well for this stepper? I'm using a 24V power supply with 36amps capacity and this driver from amazon couple onto an arduino uno.(Witbot CNC Shield Expansion Board V3.0 +UNO R3 Board for Arduino+ A4988 Stepper Motor Driver With Heatsink Kits for Arduino)
https://www.amazon.com/Witbot-Expans...bot+cnc+shield
