Hi hornet, hope this helps.
I'm having problems finding the wiring diagram for
Slo-Syn 8 wire stepping motors. The part number on
the motor is M063-Le-507e. The label on the motor also specifies this: connect per 225373. Does anyone have any
wiring diagrams for these motors?
This is a better, more informative one.
http://www.slosyn.com/manuals/SS2000MD7.pdf
Thanks for your help.... GrahamIT. I was wandering if you would know how to cross-reference my
wiring harness though.... I have these colored wires... Red, Brown, Yellow, Orange, White/brown,
White/red, White/yellow, White/orange, and chasis ground green.
Sounds like you'll have to set to with an AVO meter and find out which pair of wires join to which coil, sorry I couldn't be more helpful.
Does anyone know how to connenct a SLO-SYN M063-CS09 ?
It has a 8 pin connector
WINDING COLOR CODE:Originally Posted by hornet
Winding 1 Yellow and white/yellow
Winding 2 Red and white/red
Winding 3 Brown and white/brown
Winding 4 Orange and white/orange
Wiring in Series:
Yellow A Phase
Red B Phase
Brown C Phase
Orange D Phase
white/yellow connects to white/red
white/brown connects to white/orange
Parallel:
Yellow connected to Red (A)
white/yellow connected to white/red (B)
Brown connected to Orange (C)
white/brown connected to white/orange (D)
GREEN IS CHASSIS GROUND CONNECTION.
Hope this helps.
Jerry
Hi i have an 8 wire portescap disc magnet stepper motor and i dont know how to wire it and what to wire it too. Could you help please.
I figured out this method to identify any 8 wire motor. Hope it helps.
You will need an bi-polar driver that is set to spinning to work.
Identify leads on a 8 wire stepper motor « Dreamation Workshop
