23lm-c355-p6v
Results 1 to 15 of 15
Thread: 23lm-c355-p6v
    Apr 2007
    turkey
    Default 23lm-c355-p6v
    Does anyone know the specs of this Step Motors, V/Phase and A/Phase values does not exist on labels, i checked many. I contacted with Astrosyn and Minebea, Astrosyn said that this is a motor produced by Minebea, searched on their site and saw closer models but not this one with C355, i mailed Minebea but no reply from them for weeks.
    Found a site, he does some work with desktop-cnc and he uses "23LM-C355-P4", on the site it says "2.6V / 2.0A" for P4 ones, but not P6 again
    Thanks.
    Apr 2006
    Turkey
    Default Here are the specs i have found for 23LM-C355-P6V
    23 = size in inch
    L = Laminated Stack Stepping Motor ( same for P and K )
    M = 1.8 ( Y = 0.9, U = 3.75 and Q = 5 )
    C = Phase Hybrid( Same as M,Q,K,H,Z )
    3 = Motor Length = 49.5 mm
    5 = ?
    5 = ?
    P1-P9 = Custom with pulley ( 01-99 = Custom , G1-G9 = Custom with gear )
    V = With connector ( W = Without connector , None = Without connector )
    Bipolar
    Rated Current = 1.5 A/Wdg
    Winding Resistance = 2.2 Ohm
    Holding Torque = 6.2 Kg-cm
    Inductance = 5.5 mH
    Rotor Interia = 0.110 Kg-cm2
    Detent Torque = 550 g-cm
    Weight = 450 gr
    If you want to get the full pdf file i have please send me an e-mail
    Cheers,
    Firat Kocak
    May 2007
    India
    Default 23LM-C355-P8w and 23LM-C355-P9V
    Hi
    by any chance you have spec sheet for 23LM-C355-P8w and 23LM-C355-P9V steppers, They have 6 wires so i am guessing they are unipolar, i have checked the Winding Resistance with a multimeter and they are 2.2 Ohm, but wanted to know the current rating.
    Shivajee
    Dec 2008
    asdcz
    Default stepper
    is that stepper useful to a cnc machine? i live in argentina and its hard to find good steppers. i would really apreciate if you could send my the pdf file.
    thanks
    _DIego
    Jul 2009
    TURKEY
    Default 23LM-C355-P6V pdf spec dosyası
    MERHABA;
    23LM-C355-P6V
    Bu motor la ilgili pdf dosyası varsa yollıyabılırmısınız
    saygılar
    kubilayortal@gmail.com
    Jan 2010
    I found this document also which describes that particular Unipolar Astrosyn 23LM-C355-P6V http://www.asr.org.tr/pdf/Vol14No2p139.pdf
    I found one of these steppers in a junkyard Lexmark 2831 Plus Forms Printer which drives the dot-matrix print head. Another pancake stepper (55SPV2505NA) drives the paper feeder and is a 7.5 Deg. 8 Ohm coil with a gear. Lots of other goodies which can be cannibalized - toothed belt/pulleys, .54" dia. (14mm) shaft x 18", bushings, 1.5A driver chips/transistors, power supply etc...
    Most of my CNC is comprised of recycled printer parts, and the bigger/older the printer the better steppers they have. Big enough to make a Dremel based router and hopefully manage a palm sized router when I get it developed to that stage.
    Mike
  7. #7
    Jul 2004
    Italia
    I too would like the datasheet for a 23LM-C355-P9V stepper motor, they should be 1.5A but I'd like to check!
    Timothy Tramontin
  8. #8
    Jan 2010
    Default 23LM-C355-P9V
    Liander, if you refer to firat kocak's post in this thread the "P9V" suffix indicates the drive pulley or gear pressed on the shaft the type of connector on the motor. I would suspect that it will have the same specs as my "P6V" as I use. I use this to run a Z-axis and 1/4-20 threaded lead screw with no more than a Dremel tool for a load (or a small laser). There seems to be very little documents available so best 2 out of 3 searches says it is a 1.5 amp/coil motor. It is also a unipolar (only type I use so far).
    From the PDF link I posted which agrees with previous postings:
    MARCA MINEBEA Co. Ltd – ASTROSYN, Stepper Motor, Type 23LM-C355-P6V
    Rated Current: 1.5 Amps Detent Torque Nm (g-Cm): 0.0540 (550)
    Winding Resistance: 2.2 Ohms Rotor Inertia (Kg-Cm2): 0.110
    Inductance: 5.5 mH 1.8 Deg/Step
    Holding Torque Nm (Kg-Cm): 0.614 (6.2) 200 Steps/Rev.
    Good luck, Mike
  9. #9
    Jul 2004
    Italia
    Thanks Mike, I've done a few tests and they seem to be 2 ohm per winding and 2A though, they have an IBM P/N so maybe they are a custom order?
    Timothy Tramontin
  10. #10
    Jan 2010
    Mine also labeled with Astrosyn, and Minebea, made in Taiwan. They could have been custom order for Lexmark, but also may just be "extinct" under that numbering system. I found this also (Google is amazing) with very similar specs in Minebea catalog - look at 23KM-K355U http://www.eminebea.com/content/html...pdf/23KM-K.pdf
    I think you are close enough with the data at hand to be able to make an educated choice how to drive it.
  11. #11
    Jul 2004
    Italia
    thank you very much for the help!
    Timothy Tramontin
  12. #12
    Nov 2010
    Default Wiring Color Codes
    If I can get a copy of the Data Sheet for the MINEBEA 23lm - C355 stepper motor.
    I am trying to identify the correct external wiring. This unit appears to be hard wired I would like to validate the A A\ B B\ pairs and polarisation.
    orange
    green
    white
    white/red
    black
    pink
    brown (old sillyputty color)
    white/green
    Carl
  13. #13
    Oct 2008
    Italy
    Could this Minebea stepper motor 23LM-C355-02 be used on Proxxon MF-70 with the
    ·3 Axis CNC Stepper Motor Driver Board Controller TB6560· found on ebay?
  14. #14
    Feb 2012
    Sri Lanka
    Quote Originally Posted by firat kocak View Post
    23 = size in inch
    5 = ?
    5 = ?
    Bipolar
    Inductance = 5.5 mH
    Weight = 450 gr
    Cheers,
    Firat Kocak
    Dear Firat Kocak,
    pl send me the full pdf file of 23LM-C355-P6V
    Thank you
    chamilaj@gmail.com
  15. #15
    Jun 2012
    Default stepper motor wiring
    I pulled a few of these (23lm-c355-17) motors from a printer and am building a small cnc router, but there was no information out there, so I figured out the wiring.
    The wiring is as follows:
    blue a+
    tan a+
    red b+
    black b+
    yellow b-
    white b-
    green a-
    orange a-
23lm-c355-p6v
23lm-c355-p6v
