I can startup and wiring your parts.
contact by my email
mattcnc@protonmail.com
Hello, Everyone..
I purchased the longs Chinese
4 axis cnc kit with nema 23 steppers and the 6560 board and power supply which only goes down to 19 volts. After obtaining what information I could on my own due to their lack of documentation I started to build the electronics. I have everything hooked up but the steppers don't respond. I noticed the information I did get from them stated that I need to run this on a pc with Windows XP. Well Mach 3 is what I'm running. First. I would like to know what I need to do to make it work with Win 7 if I can. Will it work on XP mode in Win 7? Second. Can anyone give me the correct Mach 3 configuration for this board? There are allot of different information in these threads and its all great but can be overwhelming. Any info from you guys would be great. I'd like to keep it simple as I can just to get it going than approach the modifications from there on. Thank you all in advance.
Troy
contact by my email
Here’s what I’ve got so far. XP Pro with service pack 3 on the way as well.
