I get the same number, but there might be something else causing your parts to come out undersized. Are you sure the tool is really the size you're assuming it is, not slightly fatter? Are you accounting for backlash? Are you using your CAM program correctly, cutting to the outside of the part boundary and not on the line or inside it?
