Those motors need about 4.5amp? And your driver is 3.5amp maximum? Most likely it's limited in some way, so as not to blow up though. So maybe you need new drivers. Never a good idea to run things maxed out either. I read somewhere that a good rule is to have 2.5x the power that you actually need to drive the most powerful motor. Don't know if this is true or not though.
