New Machine Build Mpg without mach3
Results 1 to 3 of 3
Thread: Mpg without mach3
    Sep 2017
    Italy
    Default Mpg without mach3
    I am italian
    I have this problem
    I need to check this stepper manually with a mpg but without mach3
    I put photos of what I found online as documentation for links
    Needless to say ... it does not work and I ask advice to who can help me
    I connected the mpg to the db25 serial port but nothing
    Obviously, the tense wiring you see in the picture is obviously a quick test
    Attached Thumbnails Attached Thumbnails Mpg without mach3-img_1934-jpg   Mpg without mach3-img_1935-jpg   Mpg without mach3-img_1921-jpg
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: Mpg without mach3
    looking at your photos
    I can not see any wires between the MPG and a 5V power supply !
    the MPG does not have a direction output so you will need to detect the change from the A & B channels
    Mpg without mach3-using-d-type-flipflop-detect-direction-jpg
    for a very simple test without using a quadrature decoder circuit to generate the Direction signal
    you could connect the MPG to a 5V supply and us the A+ to provide the step signal
    and use a toggle switch to control the motor direction
    Mpg without mach3-simple-test-toggle-switch-direction-jpg
    John
    Sep 2017
    Italy
    Quote Originally Posted by john-100 View Post
    John
    Thank you John
    also i had your doubt not seeing current 5 volt on mpg
    I would do a trial giving him current and hoping he would not break anything
Mpg without mach3
Mpg without mach3
