Need Help!- 4 wire stepper motor pin out
Good evening guys.
I have a small nema motor with 4 wires,
Red, black, green and blue.
I want to write this motor to a switch to manually move it in clock wise and counter.
This is not for a cnc machine but rather for different application.
Do I still need to buy a motor drive, or can I connect two wires to a power source?
Does the red and back correspond to a winding? And so so the green and blue? Or is there a different combination? My multimeter is broken..
Thanks Similar Threads:
Re: 4 wire stepper motor pin out
Yes, you'll still need a motor driver.
If you don't have a multimeter, you could try connecting a pair of wires together and turn the motor shaft. If you short together a winding pair, the motor will be harder to turn..
Yeah because steppers are PWM is that right?.. I realized that last night after I posted.
Forum Rules
