Need Help! System with two stepper motors and manual control
Results 1 to 3 of 3
Thread: System with two stepper motors and manual control
    Feb 2011
    Exclamation System with two stepper motors and manual control
    Alright folks. I need to build a system made from two steppers motors that will be mounted opposite to each other and rotate in same direction (first motor have to rotate clockwise and second counterclockwise). The system will be controlled manually with button for stop/run , forward/reverse and knob to control the speed of motors. Can I connect those two stepper motors to one driver? Also what will be the easiest/cheapest way to build system like that?
    Member coherent's Avatar
    Apr 2003
    Arizona, USA
    Default Re: System with two stepper motors and manual control
    When you use a software driver like Mach 3, you can simply slave one drive to the the other and reverse motor direction. With a system like you describe, it depends on the electronics and whether you are using a single driver or separate driver for each motor. You can reverse the direction of a stepper motor by simply reversing the current in one set of the coils.
    Feb 2011
    Quote Originally Posted by coherent View Post
    That's what I did on my CNC router. But I don't want to use any software. This will be simple device that will spin a item so I can wind some rope around it.
