Can I use 2 Motors for 1 axis without slaving one to the other?
Results 1 to 10 of 10
Thread: Can I use 2 Motors for 1 axis without slaving one to the other?
    Mar 2017
    Default Can I use 2 Motors for 1 axis without slaving one to the other?
    Hi
    I currently have my X axis using 2 motors and the 2nd motor is connected to A axis on my board and is slaved to X axis.
    Is it possible to connect the 2nd drive to the X axis output and use both motors from the same signal?
    Dec 2003
    Default Re: Can I use 2 Motors for 1 axis without slaving one to the other?
    If the system is capable of electronic gearing then it should be possible, I do it all the time with the Galil Motion cards.
    (You can even change the gearing on the fly, if needed!).
    Mar 2017
    Hmmm
    Why do I need electronic gearing??
    Dec 2003
    Electronic gearing usually refers to using one encoder as a slave off the other at what ever ratio you want, in your case it sounds like 1:1.
    Al..
    Member Azalin's Avatar
    Mar 2014
    Turkey
    In my 3 axis akz250 bob I use 2 drives and 2 motors with the same signal.
    Sent from my GT-I9300 using Tapatalk
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
    Mar 2017
    Quote Originally Posted by Azalin View Post
    How can I do it on mine? just unplug the pins from the A axis on the BOB andd plug them in the same pins the motor of X axis is? and disable the A axis from mach3?
  7. #7
    Mar 2014
    Turkey
    That's what I did but as I said my bob is 3 axis so I don't have an A axis. Using the Y signal axis to drive 2 drives was the only way.
    What BOB do you have?
    Suat
  8. #8
    Mar 2017
    My BOB has 5 axis output. But once when I tried to home the machine and for no apparent reason the 2 motors rotated in the opposite direction. So I want to have them on the same output to avoid this happen again in the future.
  9. #9
    Jul 2016
    Quote Originally Posted by jimskeet View Post
    Hi
    Hi Jimskeet,
    I think this may help you! Its a Multi-axis stepper driver from leadshine (Leadshine Technology Co., Ltd.) .
    Thanks.
  10. #10
    Oct 2016
    Are you sure that your homing parameters were the same for the slave axis
