https://www.linengineering.com/resou...-vs-amps-peak/
"Amps/Phase * 1.41 = Amps Peak current. Regardless of whether you remember the reason behind the 1.41 value, it’s crucial to understand this relationship because in most manufacturers, drivers only care about what peak value it can output. And step motors only care about listing the Amps/Phase value. As long as you understand what the difference is, you will be able to talk in the same language to both driver manufacturers and step motor manufacturers."
That is a quote from the article I posted. That's according to Lin Engineering. You can tell me if this is correct, I don't know.
And someone can correct me if they disagree with these two statements:
Also, the motor will not draw full amps unless running at full torque and low speed.
The stepper motor can only draw fewer amps at higher speeds before it starts to loose steps, and has less power, and less torque available. This is different from a spindle motor that has more power at higher speeds, but also less torque.
You'd have to limit the current with the switches on the driver. No, you can't run that motor with 8 Amps. That's 4.24 amps, and if you believe Lin Engineering, that's 6 Amps max peak current, but before doing that I'd recommend having a very good look at the driver manual to determine what they are talking about and what their current settings actually mean. It won't help you get better performance at faster speeds as a stepper motor uses less amps at faster speeds. Please do some tests to verify if what I've said is true. I'd like to hear about the results. You'd have to test it under load.
Increased voltage gives better performance at faster speeds.
For the heating, what is the insulation class of the wires on that stepper? Also, I'm guessing that a Nema 23 can't dissipate heat as well as a Nema 34? If you heat sink your motors with a fan, well, I've not heart of it on a CNC router, but it would be interesting to see the results.
NEMA Insulation Classes
