Need help
Results 1 to 16 of 16
Thread: Need help
    Dec 2015
    Default Need help
    Hi yall,
    Im new to the forum and well im having some problems... im working on building my own cnc plasma cutting table and well i cant seem to get the motors to work... i ended up buying the longs motor kit off amazon with 4 nema 23 stepper motors. I wired everyhting up according to what they said in the wiring diagram and nothing... when i plug everyhting in the motors get power and all lock up... i checked the driver test on mach 3 and it came back that my pulse rating was excellent... also my drivers and power supplies all have green lights as well as the bob... i dont know what i should do ive tried several different things and nothing seems to work.. any help would be greatly appreciated.
    Randall
    Member awerby's Avatar
    Apr 2004
    Default Re: Need help
    Are you using a 32-bit version of Windows? Mach3 won't run the parallel port with a 64-bit OS. Another thing you might check is to make sure the LPT port is set to EPP mode in BIOS.
    Dec 2015
    Dear sir,
    Thank you for the reply, i had a hard time finding this forum it got moved... anyway yes i have. 32bit computer and i checked the other day and my card is set in epp mode...
    Dec 2015
    Also my computer is running windows xp if that matters....
    Dec 2015
    Any help would be appreciated.... idk what to do... im thinking it has to be either mach3(i have the trail version right now), the pci card or the pci cord...
    Member Biggs427's Avatar
    Feb 2016
    If you plug a limit switch in the BOB, does Mach read a signal when it activate?
    Also, manuals are not always good. I ordered a stepper from a local (Canadian) web shop and the wiring diagram was not good at all.
    I had to proceed by trial and errors to find which wire is associated with which coil.
    Careful though, ALWAYS power DOWN the drive before you unplug the stepper from it.
  7. #7
    Apr 2004
    I think what Biggs meant to write was "power DOWN the drive before you unplug the stepper" - and give a little extra time for any caps to drain.
    Looking at the feedback on Amazon: https://www.amazon.com/sp?_encoding=...b=&vasStoreID= , it seems that Longs isn't as unresponsive as some Chinese sellers. Have you tried asking them what might be going on? I'd look particularly at the positions of the DIP switches - it seems that at least one person thought they were upside-down.
  8. #8
    Feb 2016
    Quote Originally Posted by awerby View Post
    You are right, I typed too fast; I corrected the post.
    Thanks!
  9. #9
    Dec 2015
    Thank you for the repies guys! I will try swiching the dip swiches around in the morning after work... also i dont have any limit switches yet. Should i go ahead and order some?
  10. #10
    Dec 2015
    Also i havnt tried different wiring combination s on the steppers cause i didnt want to burn them up... but if it isnt going to burn them up ill give it a try
  11. #11
    Feb 2016
    A limit switch is just a contact. You can just take a wire and jump the limit input and ground or vcc. I don't know which one your bob needs
  12. #12
    Dec 2015
    Quote Originally Posted by Biggs427 View Post
    Ok ill also try that in the morning.. thank you
  13. #13
    Dec 2015
    Ok so i wired a estop up 2 the bob in pin 13 and the ground connection and mach3 doesnt see it.. i tried flopping the wires around too nothing... this is what i was afraid of... not what next? Bad pci card, cord,maxh 3 settings? Also btw the pci card is add on card.... thx
  14. #14
    Dec 2015
    Also i made sure to set the port to 1 and the pin to 13...
  15. #15
    Dec 2015
    Ok guys i went to the college yesturday and tried seeing if i could get anything to work there... no go.. the reason i tried that computer is cause i know the pci card works on it (it runs a plasmacam)... any more suggestions on what i should do?
  16. #16
    Dec 2015
    Ok guys finally got the motors to turn.. i ended up buying a usb bob from build your cnc and it looks like a really nice bob.. anyway i the motors not turn.. im not sure if it was the bob, the parrellel cable, or the printer card... at least now they at least turn...lol thx for your help
Need help
Need help
