Need Help! 425oz motors constantly stalling - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 25 to 36 of 50
Thread: 425oz motors constantly stalling
  1. #25
    Oct 2015
    Default Re: 425oz motors constantly stalling
    thank you for advice I will sure try this out! I think I messed about steps per mm (I don't use inches), i'm now at 3200 for this setting and when i say to machine to do +8 on Y it goes at 8cm, maybe the problem is here and I need to have a 32000 per unit instead 3200 to have millimeters. Will see what it changes.
    Yes, I haven't received the 48v yet, not throwing money on new motors until I tried everything
    Will invite aswell a friend of my who succesfully made a cnc but with leadshine drivers and stuff.
    Will post the results!
    Here I found a little calculator to mess around, gives me this :
    http://www.cnczone.com/forums/attach...d=359578&stc=1
    Attached Thumbnails Attached Thumbnails 425oz motors constantly stalling-calc-mach3-jpg
  2. #26
    Apr 2008
    I'll be at that mill on Friday I will get you all of my specs. It is a taig mill and it is set up in mm as well. That is if you want them to compare against.
  3. #27
    Oct 2015
    Absolutely, thank you kind sir!
  4. #28
    Oct 2015
    Guys, thanks to all of you people (and also to the guy who helped me in person)! I'm stalling at 95ipm now but it's ok for me haha! 1800-1900mmpm approx.
    Mach 3 settings : steps per unit (mm) 320, Velocity 1800, acceleration 250.
    Thank god I haven't bought other motor yet. But yeah it's too late for the power supply so it will be 48v in a few days
    Have a nice week end guys and keep making beautiful things with those fine machines of yours!
  5. #29
    Apr 2008
    1,2 5, and 8 dip switches are in the on position. x is 10100 steps y is 10100 steps z is 10649 steps and he is running millimeters on a taig mill.
  6. #30
    Registered James Newton's Avatar
    May 2005
    I'll bet that is a knock off DM542 driver and NOT the real one. If you want to see a driver that can actually throw a load around, check out my THB6064AH driver (from the U.S.of A.) guaranteed... NOT a knock off.
    James hosts the single best wiki page about motors for CNC hobbyists on the net:
    http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
  7. #31
    Apr 2003
    Quote Originally Posted by sanekc View Post
    Inductance is 9mH i believe!
    It sounds like you have the same "longsmotor" kit that I bought on ebay. The ad does say 9mH but the spec sheet I found for the actual part number on the motors I received said it was 6.8mH. I emailed Yolanda at longsmotor & she said it was definitely 6.8 mh. That's at least some better than 9!
    Max stepper motor rpm on 3A, 36V, 6.8 mH should be set for 265 rpm, 352 rpm on 48V. I'm going to set my axis velocities for the 36V supply that came with the kit and build a 48v linear supply later for more speed. I'd like to know how you get on with yours & hope you get it fixed. I've heard they do fine once they're set up properly.
    I don't really know much about all the numbers & the theory behind it but thankfully there are online calculators that help. Stepper Motor Calculator
    Milton in Tennessee ya'll!
  8. #32
    Oct 2015
    Quote Originally Posted by davy182 View Post
    Thank you for your trouble man!
    Quote Originally Posted by James Newton View Post
    I'm sure as hell it's some knock offs. The company is longsmotors and it was cheap as dirt, but I didn't want to throw too much money in this machine, my wife almost killed me when she saw the whole price.
    Quote Originally Posted by DICKEYBIRD View Post
    I'm a newbie so I don't really understand fully how all this stuff works, I just try this and thar and crossing the fingers it'll work out haha. Good news it's 6,8mh tho! I'm just made some basic maths and with 36v it maxes normally at 1400 mmpm and with 48 at 1600 based on rpm! I think I will reduce the speed to 1400 on the motor setup page! Thank you for the link.
    Right now my setting are :
    on the stepper driver : 2,8A peak, pin 4 on, 1600 (1/8) microsteps.
    mach3 : steps per unit - 320, velocity 1700, acceleration 250, everything else is untouched.
    I've managed to setup a touch probe with success, finally, and I started to surface the working area, cmt bit 20mm, 2mm deep pass, 1600mm. It starts ok, but I've noticed when it returns to the bottom of the plane it have some weird offset, like i've tried to draw here :
    http://www.cnczone.com/forums/attach...d=360182&stc=1
    Am I losing steps on X axis? I need to lower the feedrate to prevent this? Thank you in advance, you've been very helpful guys, appreciate this.
    Here is the video of machine's first attempts :
    Attached Thumbnails Attached Thumbnails 425oz motors constantly stalling-sans-titre-1-jpg
  9. #33
    Gold Member
    Jan 2005
    Looks more like a g-code problem to me. Post the g-code so we can see it. If it isn't g-code related at least it will eliminate it as a problem.
  10. #34
    Oct 2015
    I think it's the x axis problem, i were not smart enough to have 2 motor on this one and made it too large (800mm of gantry) so when it moves it struggles. tried to make some holes today, absolute fail with holes not aligned etc.
  11. #35
    Gold Member
    Jan 2005
    The machine makes a diagonal move in the direction opposite of what is expected. It is not missed steps and it is not stalling. Post the G-code if you really want help with this. Until we see what is being commanded we cannot begin to tell you what is wrong. I still think that looks like a commanded move and is likely in the g-code.
  12. #36
    Oct 2015
    Unfortunately ive already deleted the file, will post something else when i have this problem again. Thank you alot!
