Need Help! Nema 23, 8 wire over heat and no starting
Results 1 to 4 of 4
Thread: Nema 23, 8 wire over heat and no starting
    Apr 2017
    Mexico
    Default Nema 23, 8 wire over heat and no starting
    good morning
    I have a nema 23 model 57BYGHM004-A with 8 wire, no starting and over heat.
    http://www.cnczone.com/forums/attach...d=358460&stc=1
    this motor is conected on a driver DM542A acording this diagram:
    http://www.cnczone.com/forums/attach...d=358462&stc=1
    why no start my motor and why over heat??
    Attached Thumbnails Attached Thumbnails Nema 23, 8 wire over heat and no starting-whatsapp-image-2017-04-12-09-06-a   Nema 23, 8 wire over heat and no starting-d5jxh-jpg
    Dec 2007
    Default Re: Nema 23, 8 wire over heat and no starting
    Your steppers have 8 wires but you've provided a diagram showing 4 wires connected, so how are you wiring the steppers?
    cheers, Ian
    It's a state of mind!
    May 2015
    I have no problem running 8 wire NEMA 34's with the same DM542a stepper controllers so I'd say your wiring is wrong.. Review your wiring against the stepper motor documentation. There are 2 ways to wire them in, both require joining wires so you only have 4 physical connections.
    Rod Webster
    www.vmn.com.au
    Jun 2009
    Default Identifying the 8 leads on a stepper motor
    As you have eight leads, each of the two phases is split into two windings. You can wire these in serial or parallel to match your driver capability.
    Here is a good reference on the different winding configurations and how to identify the leads.
    Identify leads on a 8 wire stepper motor | Victor Leung
    Hope this helps.
    David
