Need Help! Pwer Supply
Results 1 to 15 of 15
Thread: Pwer Supply
    Member Gallchobhair's Avatar
    Jun 2012
    Default Pwer Supply
    I am looking at some stepper motors to replace the ones I have. The new steppers are rated
    at 3.5 amps per phase 48V.What size power supply would I need to run 4 of these. I know
    48V but what amps do I need. Do I take 3.5 an multiply buy 4 . If I do that I would need a
    48V 14 amp power supply. Is that correct. I can find power supplies at 48V but none at 14 amps
    for a reasonable cost.
    Thank You
    Don
    The time has come the woodworker said to speak of many things. 0f routers and Wood , chips and paints and stains and CNC and other things.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Pwer Supply
    Where'd the 48V come from? Most steppers would be rated 2V-5V.
    You only need about 2/3 the rated current, so 2/3 of 14, or about 9 amps.
    UCCNC 2017 Screenset
    Jun 2012
    http://www.automationtechnologiesinc...23h2100-35-4bm
    This is the motor I am looking at. I have a meanwell SE-450-36 power supply.
    Don
    Mar 2003
    Shelby Township
    Those are 4.2V motors, and ideally need a 72-80V power supply, for best performance.
    What drives are you using?
    Jun 2012
    Mar 2003
    Shelby Township
    What motors are you currently using? With those drives, and 48V, you're only going to get 50% of the performance that those 570oz motors are capable of, which may not be any better than what you have.
  7. #7
    Jun 2012
    The probotix 280oz yellow motors. Thsi one PROBOTIX 280 OzIn 8-Wire Stepper Motor
    If you would be so kind as to list what BOB Driver and Power Supply you would recomend . I will look to see what is in my reach.
    I am retired and want to boost the performance if I can . The machine is cncrouterparts 2440 not pro.
  8. #8
    Mar 2003
    Shelby Township
    Maybe try these with your drives and a 48V power supply.
    http://www.automationtechnologiesinc...l23h2100-35-4a
    Maybe buy one for the gantry and see what difference you see?
  9. #9
    Jun 2012
    Ok thank I will give that one a try. I will let you know
    I do like your UNCNC 2017 screenset. I only need to make the text in the box bigger
    and a different color so my old eay can see it LOL
  10. #10
    Mar 2017
    Why not run 2 power supplies . One on the Y axis and the other dedicated to the X and Z axis . Problem solved.
    Its not like there a lot of money
    Switching Power Supply 500W 48V 10.4A for CNC Router 115V/230V S-500-48
    personaly I prefer having more headroom than needed , as opposed to being worried about it
  11. #11
    Jun 2012
    I think I would run Z on the new stepper and X and Y on the power supply I have.
    I just need to see if the BOB I have can do this.
    Don
  12. #12
    Member Biggs427's Avatar
    Feb 2016
    Maybe the steppers are not to blame.
    Are you running your 280 half or full coil?
    If you run full, maybe try half-coil would give better results. It gives less torque but way more speed. Or if you are half coil and need more torque, maybe try full coil.
    What is the problem with your current steppers? Speed? Torque? Both?
  13. #13
    Jun 2012
    Quote Originally Posted by Biggs427 View Post
    The X and Y are good. The Z is very heavy and I have had times when it would loose steps because it could not move
    up and down. I had a time when the Z could not hold itself up.. I fixed this with springs. I had read on this forum that
    people used springs and gas struts on the Z to help. I just decided I would fix Z. I have an 8 wire motor wired as a 4
    wire.I am no pro just a hobbyist and retired looking for all the help I can get. Thank you for the reply.
    Don
  14. #14
    Feb 2016
    Which configuration out of these three are you using?
    Pwer Supply-probotix280wire-jpg
  15. #15
    Jun 2012
    Wired as a 4 wire. Like the 3rd picture.
    Don
Pwer Supply
Pwer Supply
