Need Help! API American Precsion CMD 50-C stepper drive specs
Results 1 to 3 of 3
Thread: API American Precsion CMD 50-C stepper drive specs
    Member vladdy's Avatar
    Feb 2004
    Perogie Flats, Canada
    Default API American Precsion CMD 50-C stepper drive specs
    I have not been able to find any specs on these old drivers, would like to find max voltage in and ROI current set resistor chart..
    thanks
    Jan 2006
    Lightbulb Re: API American Precsion CMD 50-C stepper drive specs
    Quote Originally Posted by vladdy View Post
    thanks
    I know this is reviving a dead post, and hoping that the info can be used by others. I found most of this info when I first purchased the CMD-50c controllers, and used it for running my cnc router. The main info needed is the ROI current limiting resistor values, which is in the cntrllr.pdf attachment.
    If anyone has any of these wasting away in storage, I hope this makes them useful. I am interested in getting more if anyone wants to get rid of them.
    DRIVE TYPE .............................. 2 phase, bipolar, constant current, MOSFET chopper, 20 KHz fixed.
    RESOLUTIONS .......................... 200 and 400.
    POWER Inputs........................................ 15-40 VDC, +5VDC for Logic 100mA min.
    Output ....................................... 0.3-3.5 amps/phase.
    LOGIC INPUTS Type .......................................... TTL compatible. Need to sink 15mA.
    Step........................................... Square wave - 10µS minimum width. Step on trailing edge. Optically isolated.
    Direction.................................... CW/CCW. Optically isolated.
    Step Mode................................. HALF/FULL. Optically isolated.
    No Power .................................. ENA/NOPWR.
    Current Mode............................ CIRCULATING/NON-CIRCULATING.
    Reset ......................................... NORMAL/RESET. Optically Isolated.
    MOTORS ................................... Maximum current rating of 3.5 amps/phase unifilar, 5.0 amps/phase bifilar. Minimum inductance of 0.5µH unifilar, 0.7µH bifilar.
    Amps
    per
    Phase Ohms
    0.3 69.8k
    0.4 56.2k
    0.5 44.2k
    0.6 37.4k
    0.7 31.6k
    0.8 27.4k
    0.9 24.3k
    1 21k
    1.1 20k
    1.2 18.2k
    1.3 16.2k
    1.4 15.8k
    1.5 14.7k
    1.6 13.7k
    1.7 12.7k
    1.8 11.8k
    1.9 11.3k
    2 10.7k
    2.1 10.2k
    2.2 9.76k
    2.3 9.31k
    2.4 8.87k
    2.5 8.45k
    2.6 8.25k
    2.7 7.87k
    2.8 7.5k
    2.9 7.32k
    3 6.98k
    3.1 6.81k
    3.2 6.65k
    3.3 6.34k
    3.4 6.19k
    3.5 5.9k
    Attached Thumbnails Attached Thumbnails API American Precsion CMD 50-C stepper drive specs-scan0006-jpg
    Attached Files Attached Files
    Feb 2004
    Default Re: API American Precsion CMD 50-C stepper drive specs
    nope ... not dead... just real quiet , lol
    thanks for the pdf file, still have three of these
