Using reduction on stepper output
Results 1 to 3 of 3
Thread: Using reduction on stepper output
    Mar 2008
    Default Using reduction on stepper output
    The mechanical XY system I'm looking at has a 1:2.5 step down to the motion belts. Everything I've seen prior has an integer ratio 1:2, 1:3, 1:4. Seems to me the half ratio will make it more difficult to define steps per mm in the controller. 1.8 deg/2..5 = .72 deg steps. I have no experience that tells me what affect that will have versus every thing else I've seen that is a multiple or divisor of .6 deg.
    Jan 2005
    Default Re: Using reduction on stepper output
    It will have no effect. The controller won't have any trouble with it.
    Sep 2006
    All you have to do is reprogram the number of steps per inch or cm and the software will take care of everything. I recently swapped out acme screws with ballscrews on my CNC router. The acme screws had 10 threads per inch which worked out to exactly 4000 steps per inch with steppers on my machine. The ballscrews have 2 threads per cm so I had to re-program Mach with 1968 steps per inch. Sometimes Mach will show XY coordinates like 1.0002" instead of 1.0000" because it cannot hit the exact position requested. It gets as close as it can. I have about 0.001" of backlash, so I am not really worried about the very small positioning error.
    Steve
