TB6600 drive from EBAY - Page 24
Page 24 of 24 FirstFirst ... 1421222324
Results 277 to 279 of 279
Thread: TB6600 drive from EBAY
  1. #277
    Registered petsat's Avatar
    Apr 2011
    Greece
    Default Re: TB6600 drive from EBAY
    Quote Originally Posted by Liustas View Post
    I noticed that my spindle motor sometimes, very randomly causes my stepper motors lose their steps.
    Hmm. Are you sure that the spindle cause the problem?
    It could be a number of factors causing that!
    Try some measurements without the spindle connected. Then same measurements with spindle connected and turned ON.
    IF it comes from the spindle then try te measures you mentioned
  2. #278
    Jan 2018
    Lithuania
    One day ago, I was engraving some logo on acrylic glass. Suddenly X and Y axis step motors started rattling and lose steps. I disconnected power from running spindle motor and stepper motors immediately started to work well. Then connected supply for spindle motor and steppers started lose their steps again. Spindle motor was ruining with no load. I measured spindle motor idle current (when it spins with no load) it draws 0.17 A at 12V. Power supply is 12V 5A.
    So that means steppers lose their steps not because of weak power supply. Voltage in power supply from idle 12.65V drops to 12.30V when all CNC machine motors are working.
    I will try to modify my motor, and see what happens. Because I suspecting electrical noise. Also my CNC wiring are not very good, they are twisted but quite messy.
  3. #279
    Gold Member handlewanker's Avatar
    Sep 2006
    Hi, it might pay you to have a look at the JAMES NEWTON web site Slowing 69.16.243.61&c=1&t=43112.846193287 .....he is selling complete DIY kits for stepper drivers using the specially selected 6064AH chip.
    This is a specially selected component kit as the Chinese assembled ones were so bad he decided to assemble a component kit for DIY assembly.
    Ian.
