HY-JK02-M and 2m542 weard behavoir
Results 1 to 4 of 4
Thread: HY-JK02-M and 2m542 weard behavoir
    Jul 2012
    Netherlands
    Default HY-JK02-M and 2m542 weard behavoir
    Hello!
    I've got a new 2m542 driver and a HY-JKM5 breakoutboard.
    I'm running mach 3 and I'm having trouble with controlling the breakoutboard.
    example:
    setup according to Chinese manual of HY-JKm5:
    X step = pin 2 dir = 14
    I've put this information in Mach 3
    Hook up the 2m542 to the x axis on the HY-JKm5, test the arrows on keyboard and nothing works. But the LED on the B axis of the HY-JKm5 is lighting up when the x axis should light up.
    As a test I've connected the 2m542 to the B axis and now I've got a working stepper, but only 1 direction! That is weird.
    Next test:
    according to HY-JKm5 manual:
    Y step= 3 dir=16
    put that in Mach 3
    when I press the arrows Z and A axis light up at the same time, not the Y axis.
    Could that indicate that my breakoutboard is DOA? Or am I missing something here?
    Jul 2012
    Netherlands
    FYI:
    the connections from the HY-JKm5 to 2m542:
    HY-JKm5------2m542
    N-------------Dir - & PLS-
    D-------------Dir+
    S-------------PLS+
    When I disconnect dir+ the stepper changes direction.
    Here is a small movie about the problem!
    Jul 2012
    Netherlands
    Solved!
    There was a fault in the manual, the pin number were faulty, next to that in Mach3 MAXNC mode was selected from installation.
    When I was watching mach3 installation guides on youtube I noticed the difference and that solved the problem.
    Apr 2015
    Default Re: HY-JK02-M and 2m542 weard behavoir
    Quote Originally Posted by Jacala View Post
    Solved!
    I'm also having the same problem please tell me the solution for it.
    tell me the PIN numbers which are correct other than manual ones.
