Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Steam Engines
Steam Engines Discuss your live steam engine creations here!
Old 01-14-2010, 07:48 AM
40fordcoupe is on a distinguished road
purty dumb question - 2 cyl marine plans
I have an old set of plans from a 1950's magazine for a model 2 cylinder open frame marine engine. The problem is a missing dimension for the cylinder block.
It is shown as 1.5" by 4.0" by ?? for the height.
OK The stroke is 0.875" and the piston height is 0.250" so what should be the depth of the bore? Also what would be a reasonable clearance between the piston and the cylinder head?
Thanks,
Bob B.
Old 01-15-2010, 02:57 PM
I have decided to just go for it. I will allow 1/16" clearance at each end of the stroke. That should be enough not to crash a piston. Thanks anyway all, Bob B.
Old 01-24-2010, 08:27 AM
miniengine is on a distinguished road
2 Cyl Launch Engine
Bob B, you stated you have plans from a 1950 magazine. Which engine and which magazine please? The John-Tom site has quite a few 2 cyl engine plans. There are photos and a video (short) of my PMR 3BI runnming on HMEM. Under Photos and Videos, I think. Ray (ironman on HMEM), miniengine here
Old 01-24-2010, 11:24 AM
Hello Ray,
PS January 1953, "Model Marine Engine Requires No Castings"
Thanks I will check out the photos and video.
Bob B,
Old 05-17-2010, 03:47 PM
akitene is on a distinguished road
Good evening Bob,
I've got this set of drawings and, accorded to the text, it's clearly stated that the cylinder block dimensions are the following: "Bore is 1" and stroke .875"." Then the cylinder block is 4" x 1" x 1" 1/2 (length x heigth x width).
Hope this helps.
Akitene
Old 05-17-2010, 03:53 PM
Thanks Akitene,
I could have guessed, but it is better to know for sure.
Bob B.
Old 05-17-2010, 04:03 PM
TarHeelTom is on a distinguished road
If you have to guess, it's always better to guess a little bit on the long side. You can always add some shortness.
Tom
Old 05-17-2010, 04:10 PM
Thanks, I have good supply of shortness if needed. LOL
Bob B.
maybe a dumb question F3RR3T DIY-CNC Router Table Machines 7 12-04-2008 05:24 PM
Dumb Question Pretorien Benchtop Machines 5 10-11-2007 11:15 AM
Dumb Question... grasshorse General Metal Working Machines 3 06-28-2007 11:15 AM
One Dumb Question Biggermens General Metalwork Discussion 14 04-11-2007 03:49 AM
dumb question rob1215 General Metal Working Machines 4 06-24-2004 12:27 PM
