Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Steam Engines
Steam Engines Discuss your live steam engine creations here!
Old 03-06-2009, 10:40 PM
GerPen is on a distinguished road
Oscillating Steam Engine
Howdy
Anybody built an oscillating steam engine? I saw plans for one on Little Machine Shop and the design looks pretty simple. I'm new to machining and looking for small projects.
thanks
Old 05-11-2009, 07:37 PM
handlewanker is on a distinguished road
Hi Gerry, I've built a few simple oscillators over the years, mostly running on poison gas (methylated spirits) LOL.
The problem with oscillators is that they exhaust at boiler pressure, which means you waste about 75% of your boiler steam/fuel capacity.
The upside is they can be made from the simplest materials practically without any machining at all.
I would say that if anyone were to contemplate an oscillator outfit as a boat drive etc, then design it with the idea of compounding to a larger cylinder to make use of the steam at high pressure and heat that exhausts from the first cylinder.
Ian.
Old 05-11-2009, 08:46 PM
Thanks for the information and the suggestion of a compound larger cylinder.
I've finished two small oscillators, the Pip Squeak and a wobbler. They are fun to watch but have little in the way of utilitarian value.
I'm going to follow up on your idea with some reading and go from there.
thanks again Ian
Old 05-11-2009, 08:58 PM
martinw is on a distinguished road
Dear GerPen,
In a couple of years...?
http://www.kbsm.org/exhibits/100-inch
Best wishes,
Martin
Old 06-07-2009, 06:46 PM
mopar92 is on a distinguished road
I built the train they have , Well it was the one in live steam magazine, looks all most like it. the only problem is the burner dosent work well. Im looking fro a gas fired unit
Old 06-08-2009, 02:49 AM
A beam engine? hmmmmmmm, if you are able to get back copies of The Model Engineer, there's a beaut beam engine in there, also an even beauter triple expansion steam engine too.
Ian.
Last edited by handlewanker; 06-08-2009 at 02:52 AM. Reason: correction to locality reference.
Old 06-08-2009, 08:35 PM
Dear Ian,
Just feast your eyes on these "boys' toys".
http://john-tom.com/
Best wishes,
Martin
Old 02-26-2010, 11:33 AM
boutje is on a distinguished road
This the one i build.
I have only let it run on compressed air.
1st Steam/Air Engine rcazwillis Steam Engines 28 11-09-2009 04:27 PM
Vee 4 Steam Engine dr kingston Steam Engines 16 10-03-2007 10:34 PM
Another First Steam Engine dneisler Steam Engines 7 04-13-2007 05:04 PM
Simple Oscillating Engine nick.gilling Steam Engines 10 03-07-2007 03:15 PM
My first steam engine! gdl357 Steam Engines 26 06-08-2006 08:00 PM
