Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Steam Engines
Steam Engines Discuss your live steam engine creations here!
Old 08-12-2008, 05:55 AM
OG LIM is on a distinguished road
my another new engine....
This Low Temparature Engines can run from the heat of your hand in a cool room.
A stirling Engine also called as a " Hot Air Engine ", uses an external heat or cool source to operate.
The engines work on a very basic priciple. When air or gas is heated it expands , conversely when cooled it contracts. Operation normally begines with a cup of boilling water placed underneath the engine. It can take as long as a minute to heat the lower plate enough for the engine to run.
The engine won't start by itself , but given a little push in the proper direction ( strong enough to coast the parts over for several cycles ) , the engine will take off and continue
running on its own. The speed may be increase as the engine heats up , and the slowly decrease as the water cools. Alternatively , it will run backwards when sitting on some ice.
This hobby engine can be a very good present for our friends & also family.
Search drawing from free piston engine ->stelzer engine Enginetuner I.C. Engines 17 08-27-2010 08:11 PM
1st Steam/Air Engine rcazwillis Steam Engines 28 11-09-2009 04:27 PM
Hot Air Engine OG LIM Hobby Discussion 1 05-04-2008 01:06 AM
engine for UHU? Jakubik Open Source Controller Boards 12 10-10-2007 09:43 AM
F1 engine project Stevie I.C. Engines 59 06-02-2007 01:19 AM
