Results 1 to 5 of 5
Thread: How long does it take
    Site Owner CNCadmin's Avatar
    Mar 2003
    to make a steam engine and are their any plans?
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Mar 2003
    Shows us your pics?
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Mar 2003
    Boston
    Paul
    That’s one thing I’ve built a lot of. See my web site. I have one unfinished engine on the living room floor because I’ve been building boilers and getting the Bridgeport in and setup.
    What are you looking for? Railroad or marine or stationary. Mostly I’ve built Marine and some small stationary engines. I wanted the Bridgeport for smaller models as my other Mill is an ARNO universal 40 taper Mill and only 1000 RPM’s. I built a small one inch four jaw chuck for a model Southbend lathe. It was a ***** doing 1/8 key slots with only 1000 RPM’s I want to start building more models, The longer I keep the other stuff the heavier they seem to get.
    <http://ourworld.cs.com/revans8770/index.html>
    New Derr boiler for my Stanley Steam car.
    Attached Thumbnails Attached Thumbnails How long does it take-derr_boiler_.75_iron_pipe_grid_.jpg
    Registered balsaman's Avatar
    Mar 2003
    Wow,
    Your work is beautiful. Simply amazing workmanship. I have always loved steamengines, ever since I had a little one when I was a kid.
    Eric
    I wish it wouldn't crash.
    Oct 2006
    canada
    re
    i as well working on my frist steam engine the boler is all ready done very sippley tub with a heat coil on the bottum to ceucleat the water from conveshion have not fire it yet woking for trying to get a lath i hat having to go to my buddy shop to use the wore out lath at his weding shop (very used and abueds)
    1. G-Code to DXF
      By WayneHill in forum OpenSource Software
      Last Post: 05-11-2013, 02:26 PM
    2. Visual Basic Controller Project
      By dwwright in forum Visual Basic
      Last Post: 02-14-2011, 02:24 PM
    3. Long Z axis machines
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 02-01-2007, 07:58 PM
    4. Long X-axis methods: Rotate the nut?
      By OCNC in forum DIY CNC Router Table Machines
      Last Post: 11-23-2004, 05:13 PM
    5. Survey, Acme rod .... how long and size?
      By johntbyrne in forum DIY CNC Router Table Machines
      Last Post: 05-27-2004, 08:48 PM
